2011 GMC Sierra, 4 dr, 5.3, 4x4
The driver side top bulb quit working.  Is replacing this something I can do myself pretty easily?
yes - fairly easy.  there are plenty of youtube videos.
Edited by Bleepster
Depends on what you consider "pretty easily".  I've changed several on my '10 and '11.  You can pull the battery out and get to the bulbs without pulling the bumper and grill.  You'll also have the windshield washer fluid tank neck in the way.
Bleepster, as it turned out when I pulled the bulb out it came on.  Apparently it just wasn't making good contact.  No idea.  But its working now.  Thanks
diy611, yes .  I did pull the washer fluid tank and got to it.  Wasn't too bad but the old light came on so I guess it was just not making contact.  Thanks
Either side is fairly easy on the dims (top bulbs), with the driver's side being easier than the passenger side. I had to remove the air filter box to access the passenger side headlight bulbs.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
