Added Freon Schrader valve bad replaced it. Now it blows cooler than outside but about it. I turned on vent no AC hot air comes out turn to recirculate and it’s cool.
not sure to try next. When I get off work will check the cooler to see if it’s dirty.
You may have gotten oxygen/ non condensibles in the system when you charged it. Clean the condenser, but if all that was wrong was a bad core. I'd bet you have non condensibles in the system now.
Did you evacuate the system to get all the air out? Vacuum down the system. Make sure it holds a vacuum for at very least ten minutes.
Never worked on ac before. When I took the cap off the low pressure side all the Freon came out. Replaced the valve and filled with Freon. All I have done at this point. Will try more when I get off work.
thanks for the input
Most likely got air in there the valve core was in two pieces when it came out. Gonna take it to shop in the next couple days to get air evacuated out
Took it to the shop. The line has threads that the Freon was escaping around the Schraeder valve. New line from gm 240$
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
