Hello got those codes i know what they mean but cant find where to looks for this ground cable any advice.also it has check engine on nothing else.and the most interesting part that it came and go away  day after day.Abs module that has 2 black color on bottom and 2 reds  had about 12.7 v
Edited by Pavlo Mykhaylenko
Would be super helpful if you could post the code meanings. We don't know what they mean. We're all not walking encyclopedias of auto repair. 😉 There's just TOO MUCH to memorize these days. Most things have to be looked up.
So codes coming and going indicate an intermittent. Those are lots of fun to diagnose. Just ask any tech. You'll have to get a good scan tool on there and do a wiggle test of the harness & connectors, while watching for a drop out or glitch in live data. Even better, watching a scope for the drop out to try and pinpoint which wire, or pin in a connector, is frigged up.
Edited by Jsdirt
P25a2 its brake system controle module Mill illumination and
U3009-00 brake control module ground 2 circuit
So as far as testing i try to check conector from abs module 2 on top and 2 on bottom witch is 2 groungs and 2 positives wires all has 12.7v cant find  diagram for that connector  if any one have access  to Mitchell  it would  be so helpful
On 7/30/2023 at 10:05 AM, Pavlo Mykhaylenko said:
2021 silverado 1500
Should still be under warranty if you're under 36k miles. Let GM fix their crap engineering.
