Looking for some input on this. I have a 2022 Sierra 1500 limited SLT 4x4 crew with the 3.0. I'm looking at either a BDS 3.5 lift/level kit or the Cognito 3.0 lift/level. The BDS kit (772FDSC) is 2.5 block lift rear and 3.5 coil over front using Fox 2.5 PE up front and Fox 2.0 on the rear. The Cognito kit (210-P1137) uses Elka 2.0 front coil over & rear shock. Both kits come with mod UCAs. The BDS kit cost about $1k more than the BDS and that cost dif is driven by the more expensive 2.5 Fox coil over upfront vs Cognito at a 2.0. Both manufacturers say I can stick with my EO wheels and tire size. BDS was not convincing on the phone, more like a strong "you should" be able. Cognito was more of an absolute YES you can. The stock setup is a 275-60-20 (33x10.8). That said, one local dealer/installer said I cannot use those stock wheel/tires with the BDS another tells me I can. So here are the questions:
1. Any experience with either of these kits on a 2019-2022 GM? How's the street ride compared to stock and what did you do with wheels/tires?
2. Any other kits you would suggest in the net 3 or 3.5 lift range?
3. Anything else you think I should consider on the subject of lifting/leveling this truck?
Thanks!
I actually went with this kit which is similar to the cognito kit that you are looking at, 210-P0879. When I purchased my truck it felt very under dampened when I would hit bumps/dips at 60+ on the highway. I was originally going to go with the bilstein 5100 set up but I didn't want something overly stiff just for highway driving. I have some back issues that have plagued me at a younger age and I need a vehicle that will take bumps smoothly. The stock suspension did that however it was under dampened at speeds. I knew Fox was more of a premier brand in terms of suspension and I've always wanted to try a set of their shocks and overall I am very pleased at my purchase. I don't think you could go wrong with Elka suspension however I personally haven't heard much about them. When I did mine I also installed the longer trail boss axles as well as the longer sway bar links for the at4x to prevent the axle from hitting the sway bar. I used the stock trail boss wheels and added 295/70/18 Nitto Recon's to keep the weight down and currently run 1.25 inch spacers until I decide on a different wheel. As far as I am aware I don't think you can run a stock wheel with the larger cognito control arm.
You need to check your stock wheel offset/backspacing to see if it will clear the bigger UCA. Thats the main issue. Once thats verified you should be able to find those specs from Cognito or BDS. If they are ball joint arms,  you should be good. If they are uniball, may have an issue.
Personally I would be concerned about getting 3.5 from just a coil over. Thats gonna be a lot of compression on the spring to get that height. But dont do a spacer, thats just asking for trouble.
If your not offroading for longer periods of time, the 2inch body foxes are more than enough. The 2.5" foxs just have more oil which helps them run cooler, which reduces shock fade. 75% of users will never heat them up. Valving is more important (liner, digressive, progressive)
If your keeping stock wheels/tires, it may look small that high too. 2.5 up front would likely level it. Meaure from center of your hub to bottom of fender lip in front amd back, then you will know YOUR trucks rake. Mine is 2" nose down.
Edited by Vincej138
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
