Few months ago I bought a 04 Sierra. Ran great for exactly 103 miles then problems started . Seller told me it still had 02 sensor code  showing ( I'll post pics)  even though he'd replaced all 4 twice . This going to be long cause I want it all out there. He replaced the following to my knowledge. 02's, map, maf, ect, PCM, throttle body, plugs, wires, coils , injectors, pretty much everything but knock sensors. I replaced 1 o2 because I saw 1 (new) was bent. Problems started with loss of power and MPG. Started running very lean. Using multimeter I've checked the wiring on everything and it all seems fine. While troubleshooting the power loss and gas mileage past few weeks , 2days ago it's developed a misfire. When you start it about 15seconds in it starts missing and sounds like crap. Like running on 3 cylinders or something. It's not everytime and when it happens turn off and on and your good .
Last night I went through the plugs and gapped them at . 40. They were all . 32 for some reason.  I check fuel pressure, it holds at 52. So I'm thinking bad injector?
I've tested 5 so far (ran outta time) 1,2,4,and 6 show 13.1-13.6
#8 shows 12.9
Still have to check 3,5,7.
But as you see in pics , problem is on bank 2.
I know this is long post, I hope someone reads it all lol.
Some of the spark plugs keep loosening. Like very loose. I  Never had that problem , they are the right size too .
The 2 pics of 02 banks volts I'm thinking shows at bad B2 CAT . I I right on that?
Not good at computers , so I'm doing my best to make this legible.Here's some more pictures got this code when it start bogging down to a stop. Hasnt happened again so far
What brand and part number plug did PO use? These engines kinda like AC Delco and NGK and the correct number already correctly gapped to .040. Platinum or Irdium. Higher mileages, I'd just go with Plats. Answer my first question.
Also some other parts that have been replaced may still be your problem. Some aftermarket brands of O2 sensors seem to have issues, same with knock sensors.
Spec on fuel pressure is 55-62 @ key on, engine off. As you start straying below that you may begin to have issues. Your 52 reading...  is that after it has sat for a minute or is it KOEO and immediate check?
Who actually replace all this stuff previously? A qualified shop or shade tree Joe? You don't just pop a new PCM in without doing another step.
Have you done a compression test on all cylinders?
Plugs becoming loose, that S_ _ t ain't right. txab is right; just because the guy installed this 'n that sure doesn't mean he bought first quality parts. Most better plugs these days are pre-gapped too so that's kind weird... Installing a PCM is big stuff, I have never done it (knock on wood) but it is certainly something that has to be done "By The Book", I'm a big btb guy having worked on Uncle Sam's stuff for 38 years.
The PCM would need to be programmed for the vehicle. A crank relearn would need to be performed also. Grabbing a junkyard PCM doesn't always cut it. I've swapped PCMs due to tuning. No issues when the steps are followed. Yes the loose plugs are concerning. That's why I wanted to know brand/part number.
I'd wonder what all brands parts were used. So many of those parts may still be involved. Something else to think about..... did he really replace all that or is he blowing smoke?
I appreciate y'all helping me out with this I really do. I'ma gonna try to add some pics n video. I'll have to look at the PCM for brand, but definitely looks new . The plugs I bought was ngk and we're already gapped. The ones the guy put in was the same ngks which again makes me wonder why he changed the gap to 32. I did find some significant exaust leaks by hooking up a shop vac and using spray bottle. The exaust manifold is leaking pretty good on passenger side. And the gasket connecting the flange gasket pretty bad leak.
My fuel pressure is still low, idk if those leaks would do that. I just tried to link the video but says it's too large. ( only 10 sec).I'm not the best at this, I can turn a wrench but the diagnostic side is definitely my weak side. That's why I say I appreciate yall
Fix the exhaust leaks first. Your O2 sensors aren't getting an accurate reading of what is happening in the combustion chamber. The PCM is trying to adjust the engine based on the lies the bank 2 O2 sensors are spreading.
The screenshot of bank 2 sensors is telling. Sensor 2 is following sensor 1.
I know you all told me these trucks like certain brands, I'm buying the manifold gaskets today and gonna work on it this weekend, is there a particular brand this old hussy would prefer? She's turning out to be kinda moody so I wanna do it right
Want it right, get OEM.  The gaskets and flange seals aren't that much, and the OE ones are quality stuff.
Especially if you need O2 sensors.  GM vehicles do NOT like any aftermarket O2 sensors at all.  We see this at least once or twice a month at work.
Well here's what I found, valve stems coated white except for #4 and 6. Ash underneath soot. Is it ok to still replace the gasket and put it all back together? Gotta have it for Monday ya know
4 and 6 look to be problematic. Could be oil leaking down the stem, or other source of incomplete combustion inside the cylinder. Since the symptoms are of a miss, I would presume the source being inside cylinder.
(Re-reads thread for memory)
A lean condition with low fuel pressure and misfires indicates fuel pump, has that been replaced?
How was lean condition determined? (Don't I remember you having low o2 sensor voltage?)
How was deficient fuel pressure determined?
Trying to see if its one problem or multiple.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,305 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
