This is a warning to all members. I placed an ad in the For Sale Forum for LED Tail Lights Wanted, I recieved a message thru GM Trucks from Mr. Jeff. He stated "I have 2019-2023 silverado tail light assembly right and left in an excellent condition $600 shipped. Best to send me a mail at [email protected]. I sent to this gmail account to tell him I was interested. He then tried to persuade me to send him payment. I told him I have Paypal and then he requested that I send him payment using "freinds and family". I told him I would not send funds using freinds and family because I could not get my money back if I did not recieve the parts. He then replied "Having issues with my Paypal. Do you have Zelle?" I said no he then requested  send funds to a hotmail account with a different name. Yesterday I received another message thru GM Trucks from Dretchad11 "Hello buddy, Are you still looking to purchase OEM LED Tail Light Assemblies for 2023 Silverado Custom? A member on here @SC MacNeil, have it available for sale. You can reach him at [email protected] ask if he still have it available for sale. Also yesterday I received another message thru GM Trucks from DanBurn35 "The only guy I know that might have one or know where one is sparkus88.. I haven't seen him on here for a some days. He also didn't return my last couple of phone calls. Here's his email [email protected]" Dretchad11 just joined the forum on Monday and has no profile and DanBurn35 just joined this forum yesterday and has no profile. This scumbag scammer has tried three times to move me from GM Trucks to gmail or hotmail or anywhere else he could take my money. This is a freindly warning to keep you guys from losing any money to this guy. Zane and any other Administrator you may want to look into Mr. Jeff,  Dretchad11 and DanBurn35.
Be careful guys!
  • Like 3
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
