I have 2019 Silverado 1500 5.3 4x4 LT. I also have a trailer that I tow often and stuff tools in the bed as well. The back sits low when I tow and have my tools in bed.
Someone suggested airbags but I don't know much about them.
Will this help the back from dropping so low? Also, if I install them do I need to lift the front?
Apparently Rough Country sells some for $350 and easy to install myself.
Thanks in advance!!
They bolt on between the leaf springs and frame. You can set them up to air them up manually from a portable compressor or a shop compressor or buy an onboard compressor. You can go crazy with options for the compressor and auto leveling and other things. You add pressure when towing to keep the rear from sagging. You don't need a lift unless you want one.
Edited by GETGONE
Leveling kit in the front I see a spacer on top of the strut so that's why you see the rear low I don't see anything as far as a lift on the rear suspension. All trucks have a rake rear higher than the front when new for hauling and when a front leveling kit is put on the truck it will sit level unloaded but when weight is added to the bed the rear will drop looking low in the rear as your seeing, without a front leveling kit when weight is added to the rear the truck will look level. If you took off the front leveling kit the truck will look more level with the weight in the bed.
Edited by Silverado4x4
That's awesome information. Thank you so much. Appreciate that a lot.
I assume the guy didn't tow much bc this ****** sits low when I tow. Lol
It looks cool when empty though!
I guess I should probably look I to the airbag system at this point.
Thanks again!
    • Those  headrest speakers look fun! Standard panoramic roof on the AT4X might be a deal breaker for me unless I can delete it. Maybe I should just supercharge my truck and call it a day. We'll see what I think of all the new trucks when I see them in person.
    • "Increase"?   You want to "increase" your turning radius?     What is your truck?  What kind of cab and bed do you have currently?  Is it stock?  Modified?  Lifted?
    • OP's quote is parts and labor.  Not just parts.     The # you found isn't the right one.  But besides that, the right # is the same price within a couple bucks.  $5802.01.    Now, factor in labor and fluids.  Book time is 17.1 hours for a Colorado 8 speed.  At $200/hr for a dealer average rate, its $3420 just in labor.  We are already at $9222.  Fluid and other necessary items, there's your $400-500 more.      Also.  Your "discounted" transmission.  Which is 99% likely quoted off of GM Parts Direct as that's the MSRP I found on their site.    You failed to note the $597 in shipping charges.  So we are right back almost to MSRP.  $5794.  Oh.  AND, you better have the $4000 for the core charge which you'd have to pay and get refunded, AND you gotta pay to SHIP THE CORE BACK.    So now you'd have paid MORE to buy that one online yourself, even after you get your core refunded.
    • I would like to know if I can increase my 2025 Silverado 2500 HD
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
