I'd like some clarity on the rain sensor please. My understanding it is not based on the windshield camera, and that it is a separate piece. Is that corrent? And, can someone please tell me exactly where the rain sensor is on 2022 Refresh 1500 Denali?
Thank you
This section doesn't really say where, but my understanding is it is in the area in front of the rearview mirror, (same area as one of the cameras)
B117AWindshield Outside Moisture/Ambient Light and Humidity Sensor
Note: Due to the sensitivity of the sensor, the wipers may swipe once upon start up or rapid lighting changes.
The B117A Windshield Outside Moisture/Ambient Light and Humidity Sensor utilizes an internal infrared LED and an optic sensor to determine the amount of water on the windshield.
The infrared LED bounces infrared light against the inside of the windshield.
The optic sensor measures the amount of light returned after  bouncing off the windshield.
With a dry windshield, all light bounced off the windshield is returned to the optic sensor.
As water accumulates on the windshield, the light input to the optic sensor is diffused and reduced.
The amount of light reduction corresponds directly to the amount of water on the windshield.
The B117A Windshield Outside Moisture/Ambient Light and Humidity Sensor interprets the amount of light returned and communicates this info to the K9 Body Control Module, which will control intermittent wiper operation
based on the sensitivity selection of the S82 Windshield Wiper/Washer Switch and the amount of water on the windshield.
My rain sensor is not working after having a new OEM windshield installed. I read somewhere that a "gel pad" or the sensor itself needs to be replaced if a new windshield is installed. Does anyone know anything about this?
Edited by MrLeadFoot
I'd be seeing a GM dealer.
Might be the sensor was damaged.
Might be some sort of calibration required?
Was the camera it that area correctly aimed?
Perhaps dealer could check/verify/calibrate both?
This was an insurance claim, and insurance uses company uses Safelite. Windshield was OEM, but the glass is wavy, so is being replaced. Camera was supposed to be recalibrated, but Lane Assist now thinks I'm still in my lane when I'm riding the line on my left. They claim it's because the glass is wavy, but I doubt that's it because when pressed right up against the glass I don't think the camera can be seeing the distortion in the glass. I think they didn't calibrate it properly. I also think they either broke the rain sensor, or possibly did not know they needed to replace the gel pad, or whatever. I think I need to let them attempt to make this right first before I can raise a big stink, although I kind of already started that ball rolling. If I was scared they'd damage something the first time, I am now quite concerned, especially if they don't know what they're doing. I should never have done this and lived with the bulls-eye chip until the windshield cracked completely. Lesson learned.
Did they actually use an OEM windshield?  Fuyao is typically the manufacturer now, but genuine GM glass will have the "GM" mark of excellence logo printed on it in addition to the Fuyao branding.
I would tell the insurance company that you gave Safelite a chance and they clearly blew it. That you want to bring it to the dealer to handle now so it's done right.
That's to bad. Safelite did our Hyundai Santa Fe windshield and  no problem's. We got a recalibrated certification.
    mans44
    mans44
  • Who's Online   4 Members, 1 Anonymous, 437 Guests (See full list)
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
