It's that time of the year again. Now is the best time to get the underside all coated up to protect from the harsh winter salt.  AMSOIL's HD Heavy-Duty Metal Protector is a great product to use to coat the underside of your truck or vehicles of choice.  It dries to a wax form and keeps the salt from causing problems. You can use the straw to spray inside frame rails and panels.  Contact me to get a quote delivered to your door or you can get it at www.syntheticadvantage.com
Here is the information from the Data Sheet.
Corrosion Inhibitor
AMSOIL Heavy-Duty Metal Protector (AMH) is an easy-to-use
spray-on product that protects metal surfaces exposed to
the damaging effects of salt, moisture or chemical corrosion.
Ideal for steel, iron, aluminum, brass, copper and other metal
surfaces.
D A T A S H E E T
G1136 10/21
• Contains additives that specifically protect against corrosion
• Displaces water and seals equipment from water intrusion
• Leaves a dry, long-lasting (up to several years), wax-like, amber film
• Sprays into hard-to-reach places
Applications
Automotive and trailer undercoat, spare tire carriers, battery terminals,
tailgate hinges, handheld tools, snow plows, mower decks and blades,
snowblowers, skid-steer attachments, farm machinery, fork lifts, metal gates/
fences and much more
Directions
Shake well before use. Clean target area prior to application. Apply in a uniform
and even manner. For precision application, use extension straw. Allow to dry for
two hours. For best results, allow to cure for 12 hours. Use AMSOIL Heavy-Duty
Degreaser to remove overspray.
