I will wait till someone posts a youTube video on how to do it. Mine runs about 205 when towing my 12K 5th wheel.
  • 3 months later...
Hello all,
I'm new here and new to the L8T 2500hd crew. We just took our first trip with our 10k 5th wheel trailer. With my previous gasser I could pull the trailer in 5th (6spd trans) gear without engine coolant temps rising.
With the L8T it runs at 210 unloaded and loaded running in 4th. But when I let it shift into 5th also a (6spd trans) the temp immediately  jumps up to about 230 or so. If I manually shift it back to 4th it immediately drops back to the 210 mark. Is this normal? Or should I be having my dealership take a look at it
Others have posted that it is normal, it is normal for my 2024.
Edited by lineman1234
better
Yea, I tried to delete the 2 comments, wouldn't let me.
It just worries me that the temperature climbs 20-25 degrees within 1 mile after shifting into 5th.
Sitting in the upper half on a Guage on a truck that's supposed to be designed for much more weight concerns me after only 45minutes of driving. When a 5.3l never batted an eye at the same weight for hours on end in the same gear with a 3.42 rearend..
I moved to the 2500 just for the Payload assurance. Now I'm not so sure..
Mine sits at 220 empty, so 230 wouldnt be much more towing.  When i say 220 it is that way without a winter front cover in -10f or colder, in the winter after it warms up.
I will see what it does the next time I tow the camper, just seeing it rise that fast worries me is all. Unloaded mine does not go above the 210 middle mark, and in 4th it stays steady at the 210 middle mark while towing. It was almost to the 3/4 line mark which marks 235 degree mark within a mile of shifting to 5th
This message sounds like you understood my message to be about an optional add-on transmission cooler. I was describing the basic auxiliary transmission cooler that is on all the gas/6L90 trucks. It is called auxiliary because it supplements the primary cooler in the engine radiator.
I'm not talking about trans temp, my trans temp stays consistent at 190 when towing. This is engine coolant temp I'm worried about.
You can run a cooler temp thermostat. You can go down to 170° without retuning the ecm.
230 deg engine coolant temp seems very high even when towing.  The cooling package should be able to keep temps around the 210 mark unless you are in very high ambient temps and pulling long hills.
That's what my thoughts are, and why does it only climb when in 5th. Unless there is something wrong with the WP, or there's an air bubble in the loop somewhere.
I know the WP is mechanical based off the front pulleys, and I don't think 600rpm would make that much of a difference in cooling power
I called my local dealer who I trust alot, and the service manager seemed like this behavior is not normal and wants to see the truck.
I will update when I know more. Again, only does this while towing. Not normal driving.
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
