Does not matter. They dont fit my 2022 gmc.
They smash the wheel speed sensor wires and brackets. 2024s must have different brackets, or zr2 might have special ones.
bottom pic has the 10 mm bolt removed from the black metal bracket, otherwise i couldnt even wedge the shock into place.
Edited by Joe97281
I did not try the control arms, and I am not going to until the I can get the knuckles and complete everything at once, or I can get enough of the brake line parts to make it necessary to use the additional mounting locations on the upper sontrol arms.   ZR2 does indeed have different wiring and brake lines than my 2022. I was able to find a pic on the internet showing the setup of the passenger side.
On the ZR2 (possibly all MY2024 and above) the pass side front brake line follows the frame rail and goes over the shock mount, then down to the caliper. They cleared out the area for the larger shocks. It looks like brake lines head back toward the rear of the truck, and sensor wires head toward the front.
My brake line stays forward of the shock mount. All sensor wires and brake lines clobber the space needed for the shock body.
This means I need 2 new hardlines, 2 new hardline to caliper hoses, and new wheel speed sensors. I am assuming the wheel speed sensors have the appropriate bracket attached for mounting to the holes in the zr2 upper control arms.
I have already ordered: 86512135, 86512134, 86546952, 86546950
parts.gmparts identifies those as the L/R speed sensors and brake lines for chassis package ZRX.
Now I need to know if all 2024 front hardlines are the same, or if ZR2 has special ones, and if they are a direct fit for MY2022. I cannot find ZRX specific hardlines on the gm website (yet).
It would also be nice to know the part numbers for the bolts and nuts that attach the brackets for the previous items to the upper control arms.
This has gotten to the point where it is no longer fun.
I know the DSSVs are a big selling point for the conversion but at the same price remote Kings might make this easier without opening the brake system. I'm going to assume my Bilstein 5100s are going to have no trouble, but now you've got me worried lol.
Good luck.
I was considering doing this in the future with my 2024 AT4, so thanks @Joe97281 for being the guinea pig and reporting on these issues. Sorry it's not working out nicely for you. I like the idea of all OEM components, but I might just do everything except the DSSV and get Bilsteins or splurge on Fox/King.
@BuckWallace, duck down and look at the brake line routing on your 2024. If the connection is behind the upper control arms (toward the rear of the vehicle) than you should have less problems.
It might be possible to add dssv to the front and leave the brake lines alone, but the clearance for the lines and associated bracket is tight.
will post pics of the brake lines and speed sensors when they come in.
Need some clarification on the skids for the part number thread. This is what I have so far:
ZR2 Skid Plates (need confirmation whether AT4X is the same):
Front Bumper/Facia Area: 84913645
Underbody (need more placement details on where this is on truck): 85637479
Transfer Case: 85569359 (may need additional holes drilled in aft crossmember. Need more details)
However that Bumper/Facia skid comes up as plastic and fitment is just (except BISON) so I dunno if it's actually part of the ZR2 package. The "underbody" skid details as aluminum.
85637479 Should be an aluminum one piece that replaces the stock plastic splash shield and engine skid. (Zr2 and at4x). I ordered one on 12/15 but am still waiting on shipping confirmation.
Alot of the other stuff is bison specific and you need the $5k front bumper to tie it all together.
drop brackets arrives. The distance between corresponding mounting surfaces is ~95mm. I have nothing to compare it to, but maybe someone else does. IMG_2594.thumb.jpeg.32ced1d910ee0518760c7c0a7f40800c.jpeg
Down there looking at my stock stuff today I noticed the sway bar end links connect to the LCA. I wonder if the ZR2 has anything different in that regard
Did some digging on this.  All the hard lines for the  brakes are the same that I can tell.  GM doesn't sell completed lines except for one or two, its all listed as "bulk tubing" otherwise.  One section they do sell is the LF hard pipe, but its the same with or without ZR2 that I can see, 2020-2024.    I suppose there is a change in how they bend the RF?
Soft hoses for the front are different.  86512134 and 86512135.
No change for rear hoses.
The front wheel speed sensors ARE different for ZR2 as well.  86546952 and 86546950.  So probably different bracket or something like that on them to go with the upper arms and knuckle, etc.
Edited by newdude
And they delivered half a pint of beer!
Have you looked to see where your brake line connections are?
My pass side intermediate line has a part number on it that doesnt exist on google, and all parts websites claim I should have the brake lines that connect behind the control arm. ( i dont)
Maybe my truck is a Frankenstein due to COVID shortages.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
