15 minutes ago, UTGOZER said:
Boom! Done!!
It turned out just as I hoped.
Again, thank you to all that have contributed to this thread.
It would be interesting to compare your suspension height measurements compared to stock. I realize the GMC fender is slightly different than the Chev so one has to keep that in mind when comparing the two brands. Would you be able to find a flat area to park ( sometimes harder to find than one would think ) and measure from the underside of all four plastic fender moldings to the center of the hubs. You may have done a certain amount of that already to set the front end even from side to side. Measuring this way takes any tire size or tire inflation pressure  out of the equation so its the perfect method to compare one truck to the next for suspension heights.
The other part I am curious of is did you measure your droop distance, if not and had a chance sometime to lift the front of the truck until the front tires are just off the cement and measure in the same way as I described. Also when the front tires are off the ground, is it the upper control arm that stops the downward travel by going against the frame stop or the shocks extending to their full length.
I'll bet it took me 15-18 hours.  One full weekend day and a few nights after work.
Having a second set of hands to grab tools and during re-assembly was super helpful.
I used 6 ton Jack Stands that start at 18"+/- tall.  I believe my Floor Jack is 6 ton too.  Second set of jack stands came in handy to hold the Lower Control Arm up during re-assembly.
There were certianly situations like torqueing the Lower Control Arms bolts where I wished the truck was further off the ground.
Tips while they are still fresh:
Start by getting the axle nut off then disconnect the steering tie rod so you can turn the Knuckle back and forth for easier access the Brake Caliper Bracket bolts and Hub bolts.  With the axle nut off you can push the stub axle in to give more access to the hub bolts.
The most tedious part is certainly the Diff Carrier Brackets.  I supported the diff with a floor jack under the pumpkin, and started by loosening the 4 bolts that go up through the brackets to the frame.  I swapped the passenger side bracket out first and left everything on that side very loose while I moved over to the drivers side.  Lower the drivers side down some to access the third bolt on top of that bracket and it helps to have the diff lowered down to get the drivers side bracket out.
Take bunch of pictures of the bolts that go through the Upper Control Arms to aid you during re-assembly.  I installed the drivers side UCA bolts backwards/upside down and it went right together like it was correct.  Oops...
  • Thanks 1
  • 1 month later...
So it seems like the working consensus is that the 84745473 and 84745475 GM torsion bars are the equivalent to the Cognito Comfort Ride components.
This has me wondering if the Comfort Ride leaf springs are also just rebrand OEM units as well. Was wondering if any of the fine GM part savvy folks here have a thought as to what GM leafs are equivalent to the Cognito leafs.
cognito leafs are made by deaver
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
