9 minutes ago, kylant said:
except for when the unloading tool falls off the crossmember, hits your head, and then you need to go get a few stitches. don't ask me how i know
I came close to having that happen as well.  I got lucky and was able to shift my head just before it dropped.
Who knew that the old enclosed face street bike helmet kicking around would come in handy ... and the neck brace from same said motorcycle accident, "repurposed"  ... just kidding 😁
  • Haha 1
does anyone have a source for those lower control arm bolts? mine have been on order for a while now, the dealer seems to be having a tough time getting them from GM. Seems like they are an odd size and the aftermarket, like Fastenal, doesn't have them either
thanks
I've ordered parts from this dealership and had good luck.
https://parts.jakesweeneychevrolet.com/oem-parts/gm-front-lower-control-arm-bolt-11549229
Ive also ordered from these guys too.
https://www.gmpartsdirect.com/oem-parts/gm-front-lower-control-arm-bolt-11549229
My local dealer in Houston wanted $27 per bolt.  I had to argue with the parts manager to get the to sell them to me for MSRP.
Good luck!
I get all my shipped stuff from GM Parts Direct which is Flow Chevrolet in NC. They have been in the online GM part game since the way back supporting forums like LS1GTO and LS1Tech and I've never heard or had issues with them that weren't resolved. They also seem to consistently have the best or even pricing with the others (TASCA...etc) but unlike the others I think they have a personal watch on their GM inventory system. IE. when the knuckles were unobtainium they were listed as backordered and you couldn't add them to cart. Other GM sites around the web you could. There's actually a rear door crew cab interior piece I'm interested in (84631258) that will show up on other sites but on theirs it says unavailable so I don't even try it anywhere else knowing the order will just bounce back.
LC bolts show available there:
Edited by Epsilon Plus
i'll try them. i have had them on order from my dealer and they say they are direct ship. it's been 3 weeks. i called another big online seller and they said they are "backordered"
i have found them for the HD up to 2019, and really the only spec difference I am seeing is they are a touch shorter, like 1/8" shorter. i'll keep bugging my dealer.
i want to do this conversion over memorial weekend
Those bolts have been on and off backorder for like 3 months now.  Took us a while to get some for a truck at work and that was in January/February.
do you have any connections?
No.  Its all dependent on the supplier and has been.  They seem to be able to handle production line hardware needs but can't fill service parts regularly.
no bolts in site. I have searched high and low. Dealer is still working on it.
This project is going down this weekend. I have 5 days off.
I ordered some grade 10.9 bolts, washers, and crimp locks,  with nearly identical dimensions (just 5 mm shorter) that should be here in the next day or so. at least I will have something. I highly doubt a grade 10.9 M18 will be significantly weaker after 1 use.
I looked at about 6 different lift instructions over the weekend. all of them reuse the factory bolts... 🤷🏻‍♂️
are there any tips/tricks to doing the diff carrier brackets? did you guys lower the diff? remove the cv axles? those look to be the biggest PITA for the swap
thanks
Edited by kylant
They were a massive pain to swap without any tips beforehand.  I wasted a lot of time trying to get the old brackets out and then getting the new ones in.
I started my project with the passenger side first and didn't touch anything on the driver's side until I completed the passenger side (with the sole exception of releasing the torsion keys on both per Cognito's instructions.
The easiest way to get the old brackets out and new ones in is to remove the protector plate (mind just went blank on the part name) that covers much of the underside of your truck.  Then, loosen the bolts on the other bracket to gain a little extra wiggle space to move the bracket you're working on.  If you leave the other side fully mounted, it will be a massive struggle to get the brackets in and out.
The driver side was impossible to remove until I dropped the plate and loosened the passenger side diff carrier bracket.  Once I did those two steps, the driver's side bracket easily slid out and the new one went in without any issue.  I felt like a complete moron after I got the new bracket in.  Seriously.  I struggled for more than an hour on the driver's side before I did those extra steps.  It was a few extra steps that took maybe 5 mins and made the work soooo much easier.
Good luck!
The other parts that I wasted a lot of time with (and ultimately replaced) was the stabilizer link bar.  GM did us a solid with these pieces of crap.  There's a guide plate added to the lower bolt on this bar that is not permanently secured to the bar.  I didn't realize this as I was removed the lower nut and was trying to get the bar free from the LCA.  Well, the guide plate popped off for me and couldn't get it back on because of how they made it.  So I was screwed by my local Chevy stealership into paying nearly double MSRP for a new stabilizer link bar.
I say this just to make sure you're careful with that one part as you disassemble everything.  I didn't have an issue with the passenger side.  It was the driver's side that gave me all the issues.  Be ready to replace if you're unlucky like I was.  I wasted a lot of time trying to get the plate back on the bar.  Not worth it in the end.
Good luck!
thanks for the tips. did you remove the cv axles or drop the whole diff at all?
looking at lift install instructions, it looks like it would be so much easier to just drop the diff, but i don't want to do that if i don't need to
i'll pay attention to the endlinks. i really don't think that retainer tab is even needed
I believe it is necessary (don't quote me) as I believe that's what prevents the ball joint stud from spinning while you tighten the nut.
I did not remove the cv axles.  I simply loosened the diff carrier bracket bolts on both sides along with removing the skid plate.  That will give you an extra inch or so to maneuver with the brackets in and out.
Check this link for GM Service Docs related to the ZR2 swap including torque specs. Uploads are limited to 4.4mb so I had to do multiple posts:
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,165 Guests (See full list)
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
