4 hours ago, Epsilon Plus said:
The u-bolts wouldn't but the block just sits under the lowest leaf between the leaf and the axle perch. Would prob just need to source longer u-bolts from somewhere. I can measure my block if you need to know exact lift. If the 3500s are already 1.5" taller in the rear from the different spring packs, then it's a wash anyway.
Rear ZR2 lift is only needed for those who want the stock rake or just to say they have the full lift. Those just looking for the factory "level" can leave the rear stuff out.
Good to know! I didn't realize that the larger springs made the 3500s higher in the rear. Did you have to do any other mods to run 37x12.5s?
While admittedly I haven't physically measured the main leaf spring pack thickness in my 3500 to compare with the 2500, what I did notice is that the length of the bottom overload leaf is shorter on the 3500 which is interesting. But as to the rear of a 3500 sitting up higher by eye vs a 2500, I would have to say no.
The reason a 3500 has longer ubolts is that the upper overload pack that sits on top of the main pack adds height to the over all spring pack and therefore requires longer ubolts to strap that all down to the axle housing, but the thickness of those upper overload springs don't affect the empty ride height. It would have to be a spacer block "under" the main leaf pack that sits on the axles spring pad "perch" that would add ride height. I haven't measured how much thread is sticking below the ubolt nuts but its probably not enough for much of a spacer block before running out of length. I've had numerous ubolts made over the years from pickups to highway tractors at a spring shop and they just need to have the proper length of rod that is pre threaded stock on each end ( and the correct diameter ) and know the profile of the bend and inner width of the bend they will have to make. typically on more popular suspensions they will have the information in their system and just require to know how long to make the ubolts  Also its very common that the thread pitch of the rod material they have has a finer thread than a factory ubolt so new special deep nuts nuts will be required which the spring shops have in stock as well as the thick hardened washers to slip onto the ubolts for the nuts to go against if required. Not sure if any of this is of help ... oh and more than likely a spring shops ubolt material is not going to have some fancy gold or silver colored plating on it, just basic raw steel and if desired it can be degreased and painted before installing. No doubt the "fancy" custom ubolts from a lift company that are plated have a nice price attached.
i am pretty certain the rear height is the same 2500 vs 3500. the top overload spring makes the 3500 a 3500. it doesn't add any height to the pack. the main leafs appear to be the same thickness.
i have had several sets of u-bolts make a spring shop. they are generally $25 each. super easy to have them do it
  • Like 3
I do find it odd why they felt the main pack bottom overload leaf needed to be different between the 2500 and 3500, there obviously is some reason to them designing it that way though.
for those of you who have made the swap, how is the ride without the DSSV shocks?
i am after the best ride possible.
my plan was to do the swap and run a set of Cognito comfort ride torsion bars. however, cognito says those bars won't work with the at4x/zr2 suspension.
so wondering if a traditional level kit with those bars or the factory "level" would give a better ride ??
This is not completely true.  I spoke with someone a few weeks ago when I ordered my comfort ride torsion bars and leaf springs.  They said the bars will work, but it requires you to purchase new torsion keys.  It would be great if they mentioned that on their site.  The SKU for the Cognito keys is 110-90771.
I plan to start the install process tomorrow morning for my swap.  I went with the Fox 2.5 HTO shocks for my truck.  No clue how good they are.  I had the Fox 2.0 shocks on my Power Wagon and liked them.  The advertising claims the 2.5 HTOs offer more control for these trucks.  We'll see how it goes.
Edited by GMCnewbie
hey. thanks for that info. so their leveling keys just need to be bought? that makes sense. I imagine the bars on the x/2 are just cranked and there is no more room to crank with the stock keys.
throw in a lighter bar that needs to be cranked more, there would not be any room. add a reindexed key and there will be adjustment.
one person also said the comfort ride full leafs and the mini-pack leafs have about the same ride quality. don't really see how that is possible??
i guess it all depends on who you talk to there...
That's absolutely correct.  I have zero experience with butt-in-seat with either the comfort ride leafs or mini-packs.  I chose the comfort ride leafs as it wouldn't require me to take apart the leaf pack.  I'm just replacing the entire setup.  Much easier in my mind.
I've spent the last 4 days under and around my truck working on the complete suspension swap.  This project is not for the faint of heart for sure.  I've done a suspension swap on my wife's Expedition 2 years ago and assumed this would probably be a little more difficult because of the leafs and torsion bars.  Man was I wildly off the mark on that assessment.  This has been a beast.  That said, it's not the worst job in the world assuming you're technically capable and have all the right tools readily available.  I have completed the majority of the work, but I'm waiting on Fox to ship me mounting bolts for my new shocks (they failed to include them in the boxes).  So the front end is just waiting on those bolts, which should be here tomorrow, and I'll be able to wrap that up.  I'm also waiting on the leaf spacer as I somehow forgot to add that to my order back in Oct.  So for now I've installed the new shocks in the back and will do the leafs and other parts in the rear in another week or so when the parts arrive.
I will share what I consider helpful tips and tricks in the next few days.  I'm mentally beat at the moment and want to get the shocks installed and the truck running before making the list.  My hope is these items will help the job go a little easier for anyone else considering this project.  There's been a lot of trial and error for me on this one as I've never owned a truck with torsion bars or leafs before.
Experiences like that are why I lean towards Cognitos "standard" kit with tubular arms (along with Bilstein shocks, and SuperSteers steering kit). I've already confirmed with them that it works from stock to 3". I'm only looking for ~1.5" to mimic a Z.
I understand what it takes to rip the suspension out. Just not sure I wanna do it in my drive way. Loosening the T bars and swapping Uppers seems much easier.
Edited by OS RR
i have done suspensions on nearly all my trucks. i am pretty proficient at it. the last full IFS kit i have done was years ago though. that involved cutting, etc...
this swap doesn't appear like it would be too difficult. i am looking forward to the final thoughts and review.
i honestly feel swapping the mini-pack would be easier than the full leafs on these trucks. supposedly the whole hitch needs to be removed the swap the leafs
I've seen that comment as well about ripping out the hitch.  I was under the truck on Sat and didn't get the sense that I needed to go that far with it.  You do have to remove the spare tire though to get to one of the shackle bolts.  I'm hoping that's all I need to do.  Regardless, I'm in for whatever's needed at this point.  I just want to get it done.  lol
You're not wrong with that line of logic.  I chose not to go with the aftermarket lift specifically because of the geometry involved with the steering and axles.  I've read that just doing the UCAs with lifts has a greater potential for causing issues down the road with failures in those areas.  Again, I don't have first hand experience to speak to that, but the comments I read spooked me enough to go the full swap route instead.  At the end of the day it's your truck right.  They're selling a ton of kits.  I can't image they're terrible or anything.  I honestly only wanted a minimal lift to clear larger tires.  I'd love to go with a 3-4" lift, but my wife is 5' tall and struggles getting in and out as it is.  lol
The other thing I'll add quickly to this is that I did all the work by myself.  My son helped for a few hours one day grabbing tools and drinks for me, but I did all the heavy lifting.  I wish I had an extra set of hands and another set of eyes on this.  That would've helped make this job a lot easier as the parts are not light at all.  And I struggled with removing a few pieces because I wasn't looking at something in the right light.  I eventually got to the right place, but I had to step away and reset to get there.
Edited by GMCnewbie
I'm guessing GM came to the same conclusion but probably because of warranty purposes.
GMCnewbie,
do you think the diff drop brackets can be used without the new knuckles and lower control arms?
basically use them with an aftermarket leveling kit?
thanks
I would guess so.  I don't believe the diff carrier brackets give much of a drop from what I could tell holding the bars next to each other.  Someone else here might have better details on the true differences between the two brackets as I was exhausted by the time I got to the carrier brackets.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
