7 hours ago, kylant said:
in my parts research all the parts are lining up except the knuckles and lower control arms. i have searched 2 different AT4x VINS and both return 2 different sets of knuckles and lower control arms. 1 set are the part numbers listed here, the other is different.
all parts are available except the passenger knuckle 85144997
several sites say that part is no longer available. confused as to what to get...
here are the parts listed:
driver knuckles: 85124365, 85144996 (listed here, confirmed)
passenger knuckles: 85124366, 85144997 (listed here, confirmed, unavailable any more)
driver LCA: 84735903, 85144990 (listed here, confirmed)
passenger LCA: 84735904, 85144991 (listed here, confirmed)
85144997 is not "unavailable anymore", its currently on backorder.  ETA is end of March for stock.
If you are trying to get one ordered, make sure you have a VIN for an AT4X HD or a ZR2 HD as a VIN is required to put an assistance case on it.  Don't give them your VIN, GM's system will reject it.
You also state you show two different knuckles.  If you are seeing 85124366 and 85124365, those are for regular HD, NOT for ZR2/AT4X HD.
Edited by newdude
  • Thanks 1
ok, thanks. so it is still an active part number.
i guess i will order all the known good part numbers
great, thank you. i was wondering why there was 2 sets listed for the at4x. obviously a mis-list
can you confirm the LCAs too?
On 3/2/2025 at 7:46 AM, kylant said:
stopped by the dealer yesterday to pick up some other part.
i looked at the AT4Xs they had on the lot. they are huge.
hard to believe they are only lifted 1.5" and have a 1" bigger tire on them than my AT4.
are they really only lifted 1.5"?
in addition to the parts list, what about torsion keys? are they the same as the other HD trucks?
GM shows 2025 AT4X standard bed is 2.86" taller than 2025 AT4 standard bed.
2500 AT4 standard bed is same as other crew std 4wd 2500s.
2500 crew std bed 4wd is 79.82
For 1500s' AT4's are shortbed.
Crew 4wd short is 75.51", lifted crew short is 78.35, and AT4X is 78.65
I find it interesting that a standard height 2500 is taller than a lifted 1500
The parts list I posted on page 10 is the complete swap, front, rear, & skid plates. Look them up at parts.gmparts.com if you need to. Scroll down and check the fitment tab and look for chassis code ZRX
On 3/3/2025 at 7:31 PM, Epsilon Plus said:
You should see it on 37s. It's a monster.
Need some walk around pictures.
Towering over a lifted JK Rubicon on 35s. If I stand next to my bed, the top rail of the bed is at my Adams apple. I'm 6'2".
Stock ZR2 height with 37*12.5x18
For those that have swapped knuckles, what torque spec did you use on the caliper bracket bolts? Im seeing anywhere from 100 ft lbs to 221 ft lbs. I didnt see it listed with the other torque specs that @Epsilon Plus listed..thank you btw.
can you post pics of the cv axle and tie rod angles? thanks
Stock ZR2
thanks guys.
those LCAs look slightly different, maybe it's just the camera angles.
are the endlinks different on the x/2?
Finally gonna do the suspension swap on my '24 AT4.  Parts have been sitting in my garage since mid-Nov.  Weather should be nice next weekend.  New wheels/tires are on order and should be here in the next week or so.  I also went ahead and bought the Cognito Comfort Ride torsion bars and leaf springs.  Not sure what to expect from all of this, but I'm excited to dig into this project.  I decided to do the Cognito parts simply because I don't plan to haul super heavy loads anytime soon.  A 22% loss in capacity shouldn't affect my usage much at all.  That and the fact that I got a really good deal on my truck last year from the dealer that even after ordering all these parts and wheels, my out-the-door price on the truck and parts included is still less than MSRP.  That's how I'm gonna justify it in my head at least.  lol
I'll post pics next week when it's all wrapped up.
On a side note, I apparently ordered a pair of the rear suspension spacers that for the Zr2 only according to the GM parts diagrams.  I clearly wasn't paying attention when I placed my order.  Let me know if anyone needs/wants them.  I think I paid around $100 for the pair.  Not sure what GM is charging for them these days.
Are you doing the full front/rear swap? Technically, you'll have a ZR2 after and will need them. What spacers are these that you refer to?
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
