1 hour ago, GATORB8 said:
Cognito is saying their Comfort Ride Torsion Bars wont work on the ZR2.
Really?  I just emailed Cognito last week asking for recommendations on shocks.  Told them I was about to convert my GMC 2500 AT4 suspension to the ZR2/AT4X parts and switch to their torsion bars and leaf springs.  They didn't say anything about the setup other than. To recommend their Elite 3" lift kit with the 2.5" shocks.  This will be very disappointing if you're correct.
To be fair, I chatted them, but I waited 15 minutes to be connected so I assumed it was one of the cognito guys.
Only thing I can think is that a different location in the LCAs require a different length that would even matter.
Edited by GATORB8
That would make sense.  Guess I need to hit them up again tomorrow as I want to start ordering GM parts before the 35% discount expires at the end of the month.  Appreciate the heads up.
Let me know what you hear.
On 4/18/2024 at 10:08 PM, Epsilon Plus said:
The ZR2 transfer case skid vs the baby Z71 skid. In the process of drilling the rear holes. Going to use through+bolts and nuts. Initially was going to tap M10x1.5 threads for one of the unused front Z71 bolts and add another, but didn't have the right 8.5mm or whatever PITA metric bit.
Fits on the 20-23 great, just need to drill rear holes.
Any particular placement of the skidplate/ From the after photo it appears that the plate is positioned rearward so the the forward bolts are @ the front of the slots.
So... I just got the following response from Cognito:
"the AT4X/Zr2 2500 doesn't share components with the the AT4/Trailboss trims. Wherein we only have a super stock package that only adds droop travel."
This is incredibly disappointing to learn, but I'm left very confused.  The main differences between the AT4 and AT4X (ZR2) are different knuckles, upper and lower control arms, and the rear leaf spacers.  The torsion bars aren't removed or even moved as far as I know.  So why wouldn't the Cognito bars work?  I guess I'll look at the torsion bars for both the AT4 and AT4X to see if there are any differences there.  I naturally assumed they were the same.  I say that because there's a thread on another GM forum for HD trucks where several guys have made the switch to the other parts and I don't recall anyone calling out the torsion bars as an issue.
Is the front LCA insertion location moved, maybe?
Not sure as I don't have the other parts in hand.  But I'd imagine anyone doing this change would then need to purchase new torsion bars as well.  That could be the case, but I don't recall seeing that mentioned anywhere.
Sounds like social media kid or intern horsecrap. There's no difference in bar length or position from any trim 2500 or 3500. The only thing different is the spring rate within the bar.
As far as the transfer case skid goes, it mounts to the same front holes although ZR2 uses two of the three bolts from Z71. The skid lays against the curved rear crossmember form-fit style. The 2024+ trucks MIGHT have the rear skid holes predrilled/tapped just like all 4x4s have the Z71 skid holes predrilled/tapped. Someone with a 24+ has yet to comment on whether they are there or not.
  • Thanks 1
As seen under my 2024 from the driver's side.
LH hole is flush, RH hole is in a 'dimple'. Hole spacing is approx' 12" apart.
The LH hole doesn't appear to be tapped. I'll check the dia' tomorrow (dark & cooling off here LOL)
Edited by revrnd
Thanks!  That's what I was assuming.  Couldn't imagine GM would go off script with the heavy duties for a single trim package.  Ok... time for me to start ordering parts!  Most likely won't do the install until late Feb or early March (bonus time) when I can order new wheels and tires.  But I want to take advantage of the GM discount on suspension parts this month including free shipping to the local stealership.
Just placed my parts order with GM.  Saved a bunch on shipping by having the parts shipped to the stealership.  Found several discount GM parts stores online that offered the parts a few dollars cheaper, but added $500 for shipping on the back end.  In the end, my total price for all parts (UCA, LCA, knuckles, differential brackets, spacers, bolts, and nuts) was $989 after all the discounts (35% for suspension parts, 15% for the differential brackets, and almost $300 in GM rewards).  I'm excited.  Parts should show up over the next 2 weeks.
On the ropes with the Cognito Comfort Ride torsion bars and leaf springs.  I'll keep an eye out for any Black Friday deals for these.
Also need to order new shocks.  Shock Surplus recommends the Fox 2.5 Performance HTO shocks.  I need to look into these to see how they compare with the Fox 2.0 shocks.  I had the 2.0 shocks on my Ram and it certainly improved the ride quality, but I felt like the truck floated a bit at highway speeds.  Cornering seemed to take a hit with the 2.0's.  If these 2.5 HTO shocks improve on that, I'm in.  Otherwise, I'll look at other options.
  • 1 month later...
On 1/11/2024 at 9:11 AM, Joe97281 said:
Front skid arrived. Takes 5 minutes to change with a 15mm socket and needle nose pliers. Pliers are needed to get the keeper off the two rear engine shield bolts.
It sits lower than the stock steel piece (to allow for diff drop).
Oversize shipping made it the same price online and shipped as ordering to local dealer.
Are the keepers like Tinnerman clips?
  • 1 month later...
On 1/6/2025 at 6:59 PM, OS RR said:
How tall is the rear lift block? 1.5"?
Yes. This necessitates the use of 3500 U-Bolts. The only other ZR2 part in the rear besides shocks is a plastic jounce bumper extension that slips over the stock pad and clips in on it's own.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
