1 hour ago, dieselfan1 said:
I fail to see what this has to do with the OPs question.
He wants to correct his speedometer, not hear your irrelevant experiences.
Go to the Avalanche forum.
Shoot he got his answer on the first page. It's the middle of the winter, just had an ice storm, now a dense fog advisory until tomorrow. Every thread goes off the rails on every forum I'm on (I'm on a few) this time of the year. Can't do anything so rambling is rampant. 😉
Edited by Jus Cruisin
7 hours ago, Haufski762 said:
Sorry been forgetting to reply with tire size.
285/75/18s
Was that stock size or new size?
I was hoping it would bug you. And it is relevant info that very little should be done without checking with the dealer. Times have changed.
Get a life you are on here constantly with little to no information.  You are such a loser.
Spare us with your lame life experiences.
Isn't it bingo night?
Edited by dieselfan1
WOW. Man your jealousy is beyond the pale. I’ll just block your miserable ass.
That is the tire size that is currently on the truck. I am not sure what these come with stock.
Isn't the factory tire size on the tire psi sticker on the door frame?
15 hours ago, Jus Cruisin said:
So you are saying dealers should be held to MSRP? Then how do you justify what the individuals got for theirs? It's OK for Joe Blow to make a killing with zero investment of property, buildings, equipment but not dealers?
No one is forcing anyone to buy those specialty vehicles. Screenshot_20240124_124105_Chrome.thumb.jpg.5403a2f591f9d1bb64300c9efdb68aac.jpgifScreenshot_20240124_123842_Chrome.thumb.jpg.1e562ddf23ebd0b9839dd04cda8f7fa8.jpg
If that's what you got out of my post then you clearly struggle with reading comprehension.  I didn't say that at all.  You had to perform a lot of mental gymnastics to get to that conclusion.
Definitely not that size.  That's the same size I upgraded to on my Trail Boss.
You likely had 33's stock (275/60/20 or with 18's. You went up to 35's essentially.   Speedo should only be off 1-3mph at highway speed. Thats not much of a jump at all. Def not 10mph, nor enough to justify cost of anything to correct IMO.
at 70mph i am doing 72. I went from 33's to the same 35ish
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,075 Guests (See full list)
