I recently purchase a new 2024 Silverado 1500 RST with the All Star Premium package.  It has the 3.0L Duramax engine for reference.  In the past few days (roughly 4 days into owning the truck) it started making an alert/alarm noise.  First it was a single note that has progressed up to a 8 note sound.  You can hear it in the video below.   Does anyone know what this could be?  The dash is empty of alerts and no alarm lights are on.   There is no rhyme or reason for when this alert happens either.  Sometimes it happens right after remote starting, other times its 1-4 minutes into driving down the road.  IT only happens once and will not happen again until I turn the truck off and restart it.
Aftermarket Lojack of some sort the dealer must have installed.  Could be an anti theft tracker.
I'd imagine it was part of some "package" your dealer installs on every car they get that everyone has to pay for because they "add it in".
Thanks for the response, that is kind of what I was thinking also.  They did install some GPS device but its suppose to be deactivated because I didn't pay for the service.
Seems you need to have them remove it...
Definitely not a noise I've ever heard from a GM truck
Edited by redwngr
I was able to location the dealer installed gps unit under the dash.  It was easy to remove due to it only having a power and ground wire.  The sound is gone!
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,240 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
