Ok, let's say hypothetically one was to have used the RC Speedo Calibrator almost 3 years ago to reprogram speedometer. Now while driving on road trip almost 800 miles from home, transmission totally fails. Diagnosis of truck reveals total failure and a replacement transmission is needed. RC mentions to reprogram back to stock prior to any service. Now if you are broke down that far from home and had to be towed to dealer, obviously changing back to stock is a challenge.
Does anyone know if the RC programming changes the ECU or does it program the Transmission module?
And many of these various programmers can only be used for one vehicle and get locked in. Since the original transmission will no longer be there, and last function of programmer was to reprogram, it will not see the programming when plugged in. If it is the transmission module being programmed by the RC device, will it be able to reprogram this new transmission?
IIRC, when first plugged in to program, it did show the VIN number and that will not be changed, just that it will have a different unmodified programming.
Sorry I don't have experience with the RC unit.
I used a FlashPaq to reprogram the speedometer for my tires, I found out later I can do the same with my Autel MaxiSys Elite.
Still, I used the FlashPaq for the 91+ octane tune so I just did the recal while I was doing that.
No transmission issues on my end.
I don't disable it when going to the dealer and I've already had them do a few transmission fluid replacement jobs ( do it every other oil change).
I would think the RC programming module would just see a new TCM program and you could reprogram from there?
I think I did revert back to stock one time after initial program but haven't since and it's been in for a number of visits since. I wasn't sure if seeing a replacement transmission would be an issue because I'm not quite sure what module(s) get programmed. And I was pretty sure that once it got used and saw/read a particular VIN it gets locked to it. So hopefully since VIN remains the same, I can update the new transmission. Hopefully homeward bound tomorrow morning with a working replacement trans and will try reprogramming once I get there. I will update once I know. Thanks
Please keep us updated!
I know all of my tools, the FlashPaq and the BTDieisel AutoSync are tied to the VIN.
The Autel MaxiSys Elite, not so much but, then it's a bit of a different animal and not used for specific programming changes as the other two - mainly for diagnostics with a few built it features for changing *some* settings.
Edited by MikeBMW
On 3/18/2024 at 8:03 PM, MikeBMW said:
Turns out this was a waste of a thread. I found that the recalibration was still in effect even though a replacement transmission was installed. It seems that the RC Speedo Calibrator actually programs part of the ECU and doesn't have anything to do with the TCU.
I don't think it was a waste at all.
We all learned something out of your experience, thanks! :)
Never a waste of time reading a thread by either of yall
    tararebecca
    tararebecca
  • Who's Online   1 Member, 0 Anonymous, 561 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
