Hello all, I am wondering if anyone here can help with a fix for my issue. I have spent some time googling over the last year or so as this has been an issue on and off, it seems this issue happens across any type of GM Vehicle.
my lines have gone which tell me where I’m going when I park. The screen displays the camera just fine, but there is a blue egg time in the top left corner and the button on the bottom right that toggles the lines view on and off is greyed out.
this has been happening for more or less the whole time since I got this refreshed 2022 in 2022 however recently the lines went and never came back, usually it fixes itself.
took it to a dealer and they didn’t help, simple answer was to blame it on my lift kit. They ignored the fact that it has been working for 90% of the time, It would just glitch once in a while, not often… but this time it’s not fixed itself
I have a GM Case open too, but it’s just hard work…
Any guidance would be greatly appreciated.
With the GM case, AND the dealership, be respectful and keep asking for 'help'. If they want to push back on the lift kit, and they likely will, ask if they can share any details as to how/why it would interfere. Explain that you want to know the details so you can discuss with the kit manufacturer to get their help as well.
Dealerships like to throw blame around but don't like to have to provide the details to justify their statements. The entire reason they don't want to cover it under warranty is because they want to charge YOU for the work (GM doesn't want to pay if they don't have to, and the dealership makes more profit on non-warranty work).
Just don't argue with them or let things get emotional. Stick to facts, remain calm, and keep expressing things in terms of "I need your help here".
Thank you for the reply! Attached here is the summary from the dealer. Basically I read this as, because I had the park assist retro fitted (chip shortage when I ordered the truck) they then had to recalibrate everything, which is why the lines don’t work.
the point which is being ignored is 1) this lines issue first happened 2 years ago, the park assist was installed in  November 2023. The lines have continued to work 90% of the time until last week. This is why I think they are wrong, and it’s also noting to do with the lift.
they mention a hard error in the system preventing the lines from displaying, which ‘cannot’ be cleared…
doesn’t add up to me! I’m wondering if they could just refresh? Recalibrate? Reboot the modules or something … they seemed unwilling to try, and told me I was lucky the camera even works with the truck this high up…
Ugh... Messy.
- Do you have any work orders for the lines disappearing PRIOR to Park Assist being added?
- PRIOR to the lift being installed?
Anything you can provide that shows that the problem occurred before anyone touched anything would possibly help you here.
They told you there's an error but the work order shown implies it's a "setting." Terminology matters... settings have configurable options, errors indicate problems / failures. Which is it?
It seems that the tech is acknowledging that installing the lift made no actual changes to the camera system. Once the Park Assist was installed, however, they had to re-calibrate the camera to account for the changed height of the truck. Why would raising the truck and adjusting the camera angle turn that feature off? And, can you PROVE that it worked after the Park Assist was installed at any point?
Dealership Service Writers are useless for discussing this stuff - they spew all kinds of bullshit that I swear they make up on the spot and clearly have absolutely no clue what they're talking about. The Service Manager is likely just as useless (the one at the dealership where I bought my truck tried arguing specific repair items with me claiming that GM was "never" going to address them yet I not only had them addressed, but had them addressed at -that- dealership).
Speaking to the Shop Foreman may get you some details, and the actual Tech as well. You could request through GM Customer Assistance to speak with either the Field Tech (or any field tech) or the District Manager that covers that dealership to better understand the details and the options. Anything that a Field Tech offers up is very likely backed by documented details that they could provide to you.
Unfortunately I never had any previous work orders for this - it was never something that could be recreated! It would happen one day, then seconds later go back into reverse and it would be fine again for months.
all of the explanation about the park assist was kinda pointless because, it happened on and off before, and on and off after, just for now, it seems to be off and not back on!
the fact it’s all over other forums makes me wonder what the issue really is!
it even says on the attached Cadillac bulletin ‘may be caused by a software anomaly’
just needs a ctrl+alt+delete and a reboot!!
The dealership has claimed that there's an error that "can't be cleared" and that would mean it will never work. So, all you need now is for it to work... Once... When you can get video of it working on your phone. Be sure to add commentary as to the time and date, and capture the mileage on your truck in the video. This would all potentially negate the "it will never work again" claim of the dealership.
As an aside... There's been a MASSIVE problem with GM's OTA updates for their trucks. I bought my truck in late October, there was an OTA update, and shortly after I started having weird error codes showing up and setting the Check Engine Light. The dealership dismissed it as "no code" (and they don't know how to troubleshoot without a code or a TSB that explicitly calls out the exact issue) and gave the truck back. On the way home, it "blew up" my dash with every error code known to mankind, reduced power, etc. They had to get TAC involved for very detailed troubleshooting (I took the truck back to them -immediately-) and determined that the Gateway Communication module had a corruption and needed to be re-flashed.
  • 7 months later...
@2022LiftedRST Did you get any resolution to this? The dealer installed my leveling kit today and I noticed the same thing - no guidelines, disabled button for them, and the hourglass. Going to call tomorrow and see if they messed with any calibration, I can’t imagine that it can detect that it’s sitting a few inches higher. It’s a pickup, loading the bed or towing could just as easily affect its angle!
Or the setting got changed.
The are several selections available.
One of the options that can be selected is 'no guidance lines'
I don't know which one is the default.
Edited by redwngr
This button on the far right that’s now disabled? Or is there some other system setting I haven’t found yet? 🤔
Hello!
I do indeed have an update!
a few weeks ago I had the front of the truck lowered back down a bit to stop a vibration I had, and the camera lines came back and have worked as normal for 95% of the time since
looks like the dealer was right! The truck was too high. I was about 12” lift on the front. I switched to adjustable struts and the shop I go to recons they lowered it back down 2-3 inches or so.
sometimes my lines disappear for a day or so, but I’m guessing that’s due to the fact I’m still around a 10” lift on 37s so that must be close to the limit for the camera knowing where it is.
Edited by 2022LiftedRST
For example I parked last night with my lines. Woke up this morning they had vanished for the first time in a while.. home again now and the lines are back
give your lines a few days to see what they want to do 🙂
I got used to life with no lines, would rather have a bigger truck than the lines 😂
I only went up ~3.5" (including tires) and kept a little rake, nowhere near 10" and 37s. I haven't unloaded the old tires from the bed yet, hopefully that makes it happy.
Lol same, I wouldn't want to go back, but damn...I really like that feature. Stupid computers. 🤷🏻‍♂️
On 11/21/2024 at 3:37 AM, 2022LiftedRST said:
Hello!
Same is happening to me no guidelines since vehicle got lifted front 1.5inch and rear 1inch so my truck is almost leveled, i will try to replicate that solution by lowering air pressure in front tires and increase in the rear. I'm wondering if it has to be something with vehicle level or just a raised front.
I purchased a 2025 Silverado 1500 LTZ. Most often the grid lines for the backup camera are not visible. I also noticed an hourglass at the top left corner of the camera display. The button to enable grid lines is grayed out. Now, on a rare occasion the system loads, the hour glass is gone and the grid lines are visible as it should be. I took it to the dealership and they didn’t know what to do about it and said “give it some time”, so I waited a month and as expected no change. I called the dealership again and they said to call GM Customer Support. GM Customer Support said to take it to the dealership so they could open a case. I now have another appointment, but I have zero faith that anybody has a clue what to do.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,479 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
