Here is one for the super educated Silverado electricians out there.  Let me give you the details:
2019 Chev Silverado (new body style) RST 5.3L crew cab.  Infotainment system is having issues as it starts to reboot multiple times a minute shortly after start up (although not always).  During reboots, it loses GPS capability (red line through on lower right hand side of screen), loses ambient temperature feed, sometimes loses climate control by touchscreen (works with physical controls), and usually will settle out and at least allow audio to be played.  Often it is XM only that is clear.  Bluetooth is staticy but still audible.  Music on SD card also static filled but audible.  Phone data like charging state, reception and battery state not visible on main screen.  When place truck in reverse, camera works great regardless of infotainment reboot status pre of post shift.  ON-STAR will operate as expected.
On good days when i start up and it only does a single reboot, then I have GPS and temperature data, and climate control capability.  Phone reception and charge state will show for about 15 seconds before disappearing.  Full control on screen of sources and settings.  However there are several things I can do to upset this applecart:
  • operating volume on steering wheel will cause screen to go black and then infotainment will reboot.  Sometimes this occurs with channel change as well on steering wheel.
  • plugging in phone via USB C or USB A port will cause the system to lock or enter full reboot loops for several minutes or more.  Rarely will it stabilize.  Apple Carplay is unusable.
  • Restarting vehicle after entire system shutdown is only way to recover the system completely.
Tried disconnecting battery for 10 minutes to allow system reset overall.  Did not remedy or help the situation.
Thoughts?  I have no idea what to do next as I do not have drawings/diagrams of the interrelationships of the stereo module with all other modules on the vehicle.  If replacing the infotainment screen/module was a slam dunk, I would lay down the cash to be done with it, but I fear that i would just be spending a ton of money to find out it isn't the issue, and I would then own two systems that are not helping me.
Any help appreciated.
Battery age and health directly affect all the computer systems. Especially after a startup when everything is booting up in all the onboard systems. Just because it cranks and fires up doesn't mean the battery is up to snuff. Low voltage drop confuses modules during their booting up.
Battery in top condition is critical in modern vehicles, it's the foundation for all the computer systems.
Thanks for the reply.  I’m not the original poster but was having the exact same issues with the exact same truck.  I had the battery checked and was told it was fine.  Just for anyone else experiencing this, I THINK I fixed it.   I was hesitant to do a complete factory reset.  But it was that or a constant rebooting system, that sometimes played music with no control to volume, station, etc….
With the constant reboots it took me about 20 minutes to get to the screen fast enough and hit the correct buttons.  I didn’t think I had managed to do it because the entire system turned off and the screen was completely black for about 5 minutes.  Eventually, it came back.  The GPS still had a red “cancel” circle over it but the next time I started the truck it worked also.
A friend and I also tried pulling what we thought were the stereo fuse(s) but it never turned off.  It was getting power but we were trying to check.  I don’t know if this did nothing or not.
good luck.
  • 3 months later...
So I was having the same issues but I was also having slow or dragging start of my engine. Today I needed to have my truck jumped 2 times and in the end replaced my battery since doing so I did a fully factory reset on my system and it seems to be working just fine now. As I thought it was due to updating my phone to IOS18 and when it was connected it would just keep restarting. But in the end the battery was the issue.
  • 7 months later...
Has anyone figured this out yet? I have the same issues. Even bought a brand new battery and whole new radio/head unit trying to replace everything I can before I am forced to take it to the dealership and pay a fortune.
We know this must be an upsetting concern, Foster. Will you please reach out to our team at [email protected] so we can learn more about your repair history? We will be keeping a very close eye out. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
Just checking to see if has anyone figured this out yet? I have the same exact issues. A new battery did not take care of issue. Intolerable at this point! Guess a Service visit is next.
We would like to work with you and act as an extra layer of assistance, Paul. We kindly ask that you email us at [email protected] with your full VIN, dealership information, phone number, and mileage. We look forward to hearing from you! By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
