Installed my factory camera at the precise location on the back of my 25' trailer and angle was set to spec. Went into setup and it won't finish calibration. I have gone 5 to 10 miles down perfectly straight roads doing slightly less than 30 MPH.
Any suggestions of what I might need to do to get this to finish calibration?
1 hour ago, MTU Alum said:
Can you select the transparent view or is it grayed out?  If grayed out, is your height dimension over 118 inches?
It's not grayed out and I just read the other thread about this talking about the 118 inches. Going to try lowering my height. Says on my display the max is much higher though.
EDIT: I may have already changed it from 123 inches to 118 inches before looking at the selection.
Edited by bruceb58
If you drive forward and select the transparent view, do you get a calibration status bar at the bottom of the screen?
I haven't looked at that screen while doing the calibration. Going to try it tomorrow.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
