I watch his video on YouTube. (The motor oil geek) Funny you would think the 0 would matter more than the 20. It doesn’t according to the video in most cases. Then more of his videos popped up. I was floored at his oil comparisons. But the test was only for a short time. Then I wondered how does that translate to actual miles driven and time. I stated before I did extended in a different time. I drove lots of miles and up to 150k miles. Now my daily’s all are north of 150k. I had a phobia of going past those miles that came from my early driving years. Different times different rules. My vehicles have different oil change intervals now from each other. Depending on usage and engine. The oil guy has a video on valvoline restore and protect. I was thinking of using that in the odyssey. It has cylinder deactivation. I’m actually worried it’s too good and may contaminate the engine. That’s the vehicle that gets the most frequent oil changes. Frankenstein engine, hate those.
Edited by KARNUT
I just watched his short video trying restore and protect in his wife’s Toyota. He said it worked. He also said his wife’s Toyota oil had 10K miles on it. And the van had 180K miles. Interesting.
  • 3 weeks later...
25 minutes in this one.
Discusses many of the things being talked about with the 6.2's and oil used and the recall.
Several interesting things.
One is that if you get a new engine it will not have the original 0W-20 oil spec recommended.
Video does talk about why.
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
