Found a great deal on a set of 35/12.5/r20 nitto ridge grapplers. Was wondering if they will fit on my stock 24 Sierra 2500 at4. Apologize if the question has already been asked but can not find a straight answer. Appreciate the help in advance
I don't have any personal experience, but it seems like the max size on stock suspension with no rubbing is 295/65r20, which is almost an inch narrower than 35/12.5. Some people even report rubbing at full lock with the 295/65s, so 35/12.5 will probably be a bit too wide on stock suspension if you don't want to deal with rubbing.
I have 35/12.5/20 Nitto Recon Grapplers on my 2024 LTZ Z71 - so they should fit on your AT4 as I think yours is a little bit higher than mine. There is a SLIGHT rub on the driver's side at full lock, but nothing serious.
Edited by kevin74
Do you have any photos?
Here are some that I have on my phone. Let me know if you need any closer or different angled pics.
3.thumb.jpg.6902d330fd85eda8d921049991fd0b51.jpg4.thumb.jpg.57ddc190de9fdf4c170c7b505c999fb5.jpg1.thumb.jpg.d3d5bb4afc978ae885c9fb1c0a9b3055.jpg2.thumb.jpg.c0722aa8086ada00af19cdb0363cd9c3.jpg
Here are some more - the GMC I'm parked next to also has Nitto's on there, but I didn't verify the size. I threw in a pic of the solid aluminum folding tonneau cover I found on close-out for $150.
7.thumb.jpg.eac7bdbc8f6a01b82df27d0542113559.jpg6.thumb.jpg.64e43bd1a0774da362e526906608425c.jpg5.thumb.jpg.c2e223290db78c16999ff3c3a5f97932.jpg
Thank you, looks great.
  • 7 months later...
I was wondering if you have a leveling kit on your 2024 chevy silverado 2500hd or is it stock because I was looking to buy a set of 35/12.5/r20 and I whated to see if it would fit with out rubing to much please let me no guys
I am "kind of" leveled. I have 2" drop shackles in the rear as we tow an older gooseneck trailer that needed the bed to be a bit lower. The tires fit perfectly with only a very very slight rubbing on the fender liner in the front at full lock when turning the wheels to the right - no issues turning left.
I ended up going with the falken wildpeak at4 in a 35/12.5/20 on my sierra 2500 at4. No rubbing at all. Have about 15k miles on them and still have brand new tread life on them. IMG_2011.thumb.jpeg.c11c98098eb0a7e2d0a2a85afda9c066.jpeg
Thanks for the info buddy . Nice truck I have a red truck to . I might get the same tiyers as you
IMG_2723.thumb.jpeg.a2607d9355493cf89205b1ec57a6fcd8.jpegIMG_2724.thumb.jpeg.fa8d7a6e22ff1826c9456d883ba36c9b.jpegThanks. Here’s  some better pictures
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
