Found a great deal on a set of 35/12.5/r20 nitto ridge grapplers. Was wondering if they will fit on my stock 24 Sierra 2500 at4. Apologize if the question has already been asked but can not find a straight answer. Appreciate the help in advance
I don't have any personal experience, but it seems like the max size on stock suspension with no rubbing is 295/65r20, which is almost an inch narrower than 35/12.5. Some people even report rubbing at full lock with the 295/65s, so 35/12.5 will probably be a bit too wide on stock suspension if you don't want to deal with rubbing.
I have 35/12.5/20 Nitto Recon Grapplers on my 2024 LTZ Z71 - so they should fit on your AT4 as I think yours is a little bit higher than mine. There is a SLIGHT rub on the driver's side at full lock, but nothing serious.
Edited by kevin74
Do you have any photos?
Here are some that I have on my phone. Let me know if you need any closer or different angled pics.
3.thumb.jpg.6902d330fd85eda8d921049991fd0b51.jpg4.thumb.jpg.57ddc190de9fdf4c170c7b505c999fb5.jpg1.thumb.jpg.d3d5bb4afc978ae885c9fb1c0a9b3055.jpg2.thumb.jpg.c0722aa8086ada00af19cdb0363cd9c3.jpg
Here are some more - the GMC I'm parked next to also has Nitto's on there, but I didn't verify the size. I threw in a pic of the solid aluminum folding tonneau cover I found on close-out for $150.
7.thumb.jpg.eac7bdbc8f6a01b82df27d0542113559.jpg6.thumb.jpg.64e43bd1a0774da362e526906608425c.jpg5.thumb.jpg.c2e223290db78c16999ff3c3a5f97932.jpg
Thank you, looks great.
  • 7 months later...
I was wondering if you have a leveling kit on your 2024 chevy silverado 2500hd or is it stock because I was looking to buy a set of 35/12.5/r20 and I whated to see if it would fit with out rubing to much please let me no guys
I am "kind of" leveled. I have 2" drop shackles in the rear as we tow an older gooseneck trailer that needed the bed to be a bit lower. The tires fit perfectly with only a very very slight rubbing on the fender liner in the front at full lock when turning the wheels to the right - no issues turning left.
I ended up going with the falken wildpeak at4 in a 35/12.5/20 on my sierra 2500 at4. No rubbing at all. Have about 15k miles on them and still have brand new tread life on them. IMG_2011.thumb.jpeg.c11c98098eb0a7e2d0a2a85afda9c066.jpeg
Thanks for the info buddy . Nice truck I have a red truck to . I might get the same tiyers as you
IMG_2723.thumb.jpeg.a2607d9355493cf89205b1ec57a6fcd8.jpegIMG_2724.thumb.jpeg.fa8d7a6e22ff1826c9456d883ba36c9b.jpegThanks. Here’s  some better pictures
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
