I’m getting very little if any airflow from the rear a/c vents in my 2024 AT4X.
its the only issue with the truck so far. Plan to ask dealer about it when I take it in for my first service in a couple months
just curious if anyone else has encountered this or if your rear a/c vents blow hard
The rear vents in the console are fed the most with the vents in the straight out position, so the button with the arrow pointed at the chest on the HVAC control head.  If you are on bi-level button, it will reduce the flow out of there and would blow from those and then the ones under the driver's seat.
Otherwise its normal.  They won't have the force that the front vents have.  Been in other vehicles with rear vents like these ones and same thing, they don't put out the air that the fronts do, they aid the front vents in cooling the back.
Edited by newdude
  • 1 year later...
I came her for this exact comment. This is a crap design. Even on full blast (I can’t then tolerate it in the front) my kids freeze in the back. With JUST the straight vents on even.
