Paintable rear bumper. GM Truck 99-03
Porsche
I bought this because i was told it would fit on a stepside sierra. But guess what. ..
It did not. So here it is for sale. It is black but it needs painted. The black is just the way it comes. If you do not paint it it will fade. I was told by my body shop that it should fit gm trucks and suvs from 99-03. I can take pics with detail to verify it. Taking best offer on this. It will look great if you paint it the color of your truck. That way you have a nice look and you do not have to worry if you get hit in the back becuase you will still have the protection unlike a rollpan. Shipping will be about $50 so give me a price that you would like it for and we can go from there. I have ebay feedback!!!
Thanks
Christopher
PORSCHE
[email protected]
:devil:
Yea I thoght it would fit but you have to do some mods to make it fit. I wanted it to but didn't want to mess with it. It is going on e-bay next week.
Christopher
PORSCHE
is this a factory part or an aftermarket? I was looking for the denali rear bumper...dont know if that is what this is? If so, i would be interested
to fit your sportside you will need a paintable rear from one of the SUVs. tahoe/yukon, escalade, or denali. i made the same mistake. i bought the SUV bumper instead of one like you are selling. yours will fit just the trucks. not the SUVs, and to make the SUV one work, you will have to use your stock brackets.
Thanks ranchhand. The bumpers are not that much different but just enought that they would not fit without some work. If any one is interested in it let me know. I will be selling this for cheap. i just do not need it at my house anymore.
Christopher
PORSCHE
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
