I recently experienced a P0452 on my '18 Sierra Crew Cab with 6.5' bed.  This fault is for the fuel tank pressure sensor reading a lower than expected voltage.  All online research I did led me to believe that one had to either remove the bed or drop the fuel tank to access the FTP sensor.
I wanted to share that I was able to lie on my back and reach around the frame and fuel tank (between fender and frame) just rearward of the fuel filler neck.  The FTP sensor is on the fuel pump header tank on the top of the fuel tank.  I didn't take any pictures, but working by feel alone, it is possible to remove the FTP sensor and even to remove the electrical connector to the Fuel Tank module.
In my case, once I removed the FTP sensor, it tested good so I re-installed it and went on to checking other things.  This meant I needed access to the vehicle side wiring harness that leads to the FTP sensor.  The FTP sensor harness joins with the fuel pump module connector harness about 8" from the FTP sensor connector.  Again by feel, I removed the connector lock on the fuel pump module connector and disconnected it's connector.  With both of these connectors disconnected, you can reach up between the fuel tank and driveshaft to pull the vehicle side harness down from the top of the tank.  In my case, I found a broken signal wire very near the FTP sensor connector.  A butt splice repair and re-connecting (again blind) and my issues were solved.
I should note that I'm 6'4" with pretty long arms so that certainly helps to be able to reach up and around the tank and frame.  IMO, anyone who is pulling the bed or dropping the fuel tank to replace an FTP sensor is wasting their time or getting paid by the hour......
Unfortunately, I did not take any pictures, but I still thought this could be helpful to let others know this sensor can be accessed and replaced without removing anything else.  I should also note that I previously owned a GMT900 ('07 Silverado Extended Cab 6.5' bed) that failed the FTP sensor and I used the same process to replace it by feel too.  I cannot verify this method works on any other cab/bed configurations.
  • Thanks 1
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 449 Guests (See full list)
