So I'm having a weird issue with my 2021 sierra 3500Hd trailer brake controller. The issue:
- Hook up trailer #A, when empty brakes needs to be set below 3 to keep tires from locking up.
- Hooks up trailer #B, also empty, turn up controller to 10 and I barely feel any braking force from the trailer when manually pushing the slider all the way. I can hear the electric brakes working on the trailer, it's just not giving enough braking force.... so it's not the same issue that others are having where it's not working at all...
-No error messages on dash.
- both trailers are dual axle and have about the same empty weight.
>● If I hook up either trailer to another truck at the yard (Ford or ram are the only other options) the controller needs to be  set at 3 or below also to keep tires from locking up. This test rules out any trailer issues!
I have searched Google and the forums and could not find any solution! Some people have tried replacing the sliding push control in dash, No luck. Browsed through hundreds and hundreds of forum posts, no answer found.
Does the truck have some "intelligent" trailer weight sensing feedback system that could be causing this issue?
Is there a specific procedure for hooking up trailer and setting controller,  that if done wrong will give low braking force?
Thanks in advance!
Edited by Metal.Dave
  • Metal.Dave changed the title to Trailer brake controller (new?) issue
    d.lowrey
    d.lowrey
  • Who's Online   5 Members, 0 Anonymous, 2,817 Guests (See full list)
