Just got my 2025 duramax home little over week ago. Check engine light came on and giving code. Took to dealer and they said a module in the radio that connects to onstar went bad but on recall. Something to do with the SDG handshake. Now i sit and wait and can't use my GM phone app to start truck or do anything. Brand new truck not even 500 miles on it. Very frustrating. Not to mention i'm getting no use of my free ONstar trial  period now.
When was your truck built (month & year are on the lower portion of the B pillar. If it was before Sept', someone dropped the ball @ the dealership.
I bought mine in Sept' & looking at the recall/update/campaign history online, my truck was updated the day before I picked it up. I later got an email from GM notifying me of it, even though it had ready been completed.
Talking to them about the email notification, they said they have to complete any outstanding recalls or updates before a vehicle can be sold.
2 hours ago, DBaker said:
I'll have to look at when it was built. I'm not sure how to see the recalls/update information or where that is at.
You can access the recalls thru My Chevrolet or whatever the GMC app is called.Screenshot_20241202_172112.thumb.jpg.267f2bceb772bb2ceafb1de39ecbbcad.jpgScreenshot_20241202_172136.thumb.jpg.5b3f82d46547fde4da1238aee65d9679.jpgScreenshot_20241202_172151.thumb.jpg.4ff2694d897c571f72d468a2e1b3196f.jpgScreenshot_20241202_172200.thumb.jpg.01d6a889837cab2d8df3c731b1527cb6.jpg
Edited by revrnd
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 507 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
