Just found a broken exhaust valve spring on hole #4.. happened to see it when I started the third pass torqueing down new head bolts after a dod delete.
I would like to do anything I can to avoid removing the head again.. what would be the second best method to replace this bad boy?
A length of cotton rope inserted via the sparkplug hole and the piston run up against it will hold the valve closed. A long stud in the rocker mount and a nut with a fork acting on the retainer will free the keeper. There may be a KD tool already fabricated for that. Or perhaps @newdude will chime in. I'm certain they don't pull heads for a broken spring at the dealer.
Compressed air in cylinder sparkplug hole using air nozzle with rubber tip easy with 2 people 1 person keeps cylinder pressured while other changes spring. Pressure in the cylinder keeps valve up and not dropping. Just make sure both exhaust and intake valves are closed before doing it.
Edited by Silverado4x4
Compressed air through the spark plug hole.  GM has a special tool valve spring compressor for gen 5 heads for replacing valve springs on car, but the aftermarket makes one as well.
Amazon.com: Michigan Motorsports Valve Spring Compressor Tool for L83 L86 LT4 Gen V Gen 5 Chevy LT1 Engine 5.3 6.2 : Automotive
Edited by newdude
This is the exact route I decided to take. Cheap spring compressor that will hopefully work twice and a hose from my compression tester that hooks directly to the air compressor. 👌
Put the piston at TDC and it won't be able to drop in enough to lose it.   Can I contact you? I've got some questions about my own dfm delete going on.
Edited by DK91105
    tblt44
    tblt44
  • Who's Online   5 Members, 1 Anonymous, 507 Guests (See full list)
