I’m  trying to swap my L83 and 6l80 in a 2014 sierra for a 2020 l86 and 10 speed trans. I don’t have the 2020 l86 harness or ecm, but I have everything else. If I get the harness and ecm for the 2020 will everything else be plug in play or what else will I need to do? No one seems to to have done this and I can’t find anyone who’s help. Thanks in advance.
Is the 2020 L86/10 speed out of a 2020 Tahoe/Yukon/Escalade?  So the 2015-2020 generation of SUV, K2XX.
Won't be plug and play with a E90 computer.
Your truck runs a E92 and all the CAN network stuff is based will that computer. Even running a newer computer from those 2020 Tahoe/Yukons that are still E92 presents it's own problems. Different type of vehicle, many revisions in tech from a 2014 so the likelyhood of any of the dash, abs and stuff like that working is very slim.
On 1/6/2025 at 5:15 PM, Sierraman92 said:
No it’s out of a 2020 Sierra
Oh.  Not good.  The T1 stuff is all different (2019-2022LTD in your case).  Nothing will plug and play.
I mean, even if it was out of a 18-20 Tahoe/Yukon/Escalade it's not great either.  All the 10 speeds have external TCMs, where the 6 speeds are internal TCM.  So you'd 99% likely need the entire engine harness/transmission harness assembly.  Then you'd have to properly set up power/ground for the TCM and (obviously) install said TCM.
You'd have been much better off building the 6L80 and finding an L86 and then have it tuned with the factory ECM to run the L86 tuning (likely HP Tuners and have someone load in the base tune for an L86 and go from there) and sell what you've got.
Could you use the L87?  Probably but you'd have to change some things around as there are differences between L86 and L87.  Front cover and water pump is all different between them, L86 is AFM (four cylinders deactivate) where L87 is DFM (all 8 cylinders are active lifters and can deactivate), etc.
Edited by newdude
Yeah at this point I guess I’m going to be looking to trade the l87 and 10 speed for a L86. But I’m going to be wanting to put a stage 2 cam and upgraded valve train in to go with the Supercharger and also pull the 6l80 and have it built. So that’s $1700 for the trans build and $3k for upgraded valve train(when I say upgraded I mean trunion rocker arms, push rods, gm performance lifters, ARP bolts/studs for heads, headers, valve covers, with mls gaskets). Ahhh what do I do??
    Tbhats2130
    Tbhats2130
  • Who's Online   6 Members, 0 Anonymous, 1,477 Guests (See full list)
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
