First off I'm not mechanically inclined when it comes to the engine side of vehicles.. I am looking into supercharging my stock 2016 1500 LT. Just looking for some information on what I should upgrade to be able to handle the supercharger. Some things I've done already, I have leveled the truck, upgraded to steel front and rear bumpers new rims and 33" tires, and getting my Borla exhaust put on this week. From what I can find looking online it seems like at least the fuel system and cooling system needs to be upgraded. Any advice? TYIA
Look at companies that sell supercharger kits. Like the Magnuson TVS kits, they have bolt on kits with everything you need to supercharge it. Plus they come with a tune for it.
If you plan to supercharge it with some random blower, it's tough to say exactly what else you will need without knowing what you plan to use.
It will be a name brand kit. Magnuson, Whipple, etc. I'm just wondering if anything else should be upgraded to make it more effective. I've looked online and seen everything from camshaft to fuel system needs to be upgraded.
The TVS1900 kits are bolt on and go. If you want to run more boost, then you need more fuel. That's where larger fuel injectors and a bigger high pressure fuel pump come into play. The stock camshaft does not need to be changed, again that is only if you want to make a lot more power or need a larger fuel lobe on the camshaft to support higher fuel requirements.
Anything other than what those kits offer will require custom tuning. The tune you get from Magnuson will no longer work and will require a shop to do the tuning. Tons of people on other forums that I frequent are running the out of the box blower and tune for years without any problems at all.
Custom tuning is still helpful because the transmissions really like to be tuned and they become the weak point with more power. The stock torque converters are pretty much junk unless it's been replaced already. The transmissions need to have the thermostat removed or have the updated GM lower thermostat installed to keep temps lower and save the fluid life. A stock 6L80e can handle 500hp easy, just can't abuse it and do dumb stuff like 6-2 power downshifts.
    ncleg
    ncleg
  • Who's Online   0 Members, 0 Anonymous, 1,514 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
