First off I'm not mechanically inclined when it comes to the engine side of vehicles.. I am looking into supercharging my stock 2016 1500 LT. Just looking for some information on what I should upgrade to be able to handle the supercharger. Some things I've done already, I have leveled the truck, upgraded to steel front and rear bumpers new rims and 33" tires, and getting my Borla exhaust put on this week. From what I can find looking online it seems like at least the fuel system and cooling system needs to be upgraded. Any advice? TYIA
Look at companies that sell supercharger kits. Like the Magnuson TVS kits, they have bolt on kits with everything you need to supercharge it. Plus they come with a tune for it.
If you plan to supercharge it with some random blower, it's tough to say exactly what else you will need without knowing what you plan to use.
It will be a name brand kit. Magnuson, Whipple, etc. I'm just wondering if anything else should be upgraded to make it more effective. I've looked online and seen everything from camshaft to fuel system needs to be upgraded.
The TVS1900 kits are bolt on and go. If you want to run more boost, then you need more fuel. That's where larger fuel injectors and a bigger high pressure fuel pump come into play. The stock camshaft does not need to be changed, again that is only if you want to make a lot more power or need a larger fuel lobe on the camshaft to support higher fuel requirements.
Anything other than what those kits offer will require custom tuning. The tune you get from Magnuson will no longer work and will require a shop to do the tuning. Tons of people on other forums that I frequent are running the out of the box blower and tune for years without any problems at all.
Custom tuning is still helpful because the transmissions really like to be tuned and they become the weak point with more power. The stock torque converters are pretty much junk unless it's been replaced already. The transmissions need to have the thermostat removed or have the updated GM lower thermostat installed to keep temps lower and save the fluid life. A stock 6L80e can handle 500hp easy, just can't abuse it and do dumb stuff like 6-2 power downshifts.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
