I have a 2008 1500 Silverado 4wd with a 4.8/4l65e combo with 207,000 miles on it. The transmission failed. I have a 2010 GMC Sierra 4wd doner truck with a 5.3/6l80e combo. Has anyone done this before?
It's a royal pain.  Different shifter, cluster, wiring harness, computers, cross member, etc.  Lots of programming to make it work.
Check over at the Performance Trucks forum for folks who have done this before.
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
