I know these knock sensor posts are ubiquitous but I've searched forums and elsewhere online and not found this particular circumstance -- everything tests good with the multimeter.
I was getting P0327 and P0332 codes, so low circuit voltage, both banks. I replaced the knock sensors and harness. Codes came back. I researched online for tests for the sensors and for the main wiring harness after the connector. I did those tests.
Sensors both show 100.4 kiloohms, which is right where the GM manuals say means good.
On the harness side, I get a good reference voltage on both bank1 and bank2 - 1.4 millivolts with key off, 18.4 millivolts with key on.
Also on the harness side, I tested continuity on both wires -- that is, one lead on light blue bank2 spade at connector harness side, other lead on pin 11 at PCIM -- continuity; same on dark blue bank1 spade at connector harness side and pin 51 at PCIM - continuity.
So now I'm stumped: sensors test good, wiring harness tests good; still codes come back after clearing.
If anyone has any suggestions on other causes, tests, solutions, I will be exceedingly grateful.
I've seen the codes come back with aftermarket knock sensors, always had good luck with AC delco units.
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
