Little more info needed if ur asking for help. 2 common leak issues are Shark Fin or rear high level stop/cargo light .
Where is your stain location?
Fix the leak first obviously.  The headliner isn't too difficult to clean.  The third brake/cargo light was leaking when I bought my truck used.  Headliner was stained all over the back.  A new gasket and everything cleaned up nice.  Can't even tell it was ever there.
Edited by Texasdeere
Driver side front and along back both sides.  Driveway is sloped front to back where truck is parked.
Thanks for your quick reply.  I suspect the shark antennae.  Back stoplight paint has peeled back about 6” so I suspect needs caulked as well.  Been parked same location since new.  Exposed to elements.
I notice you have the max tow package with same engine as mine.  Are you towing trailer?
No. I bought this in 2020 when it came off a GM lease, as a Certified Truck. it had almost every factory option on it including the MAX Towing, so I got whatever it had.
And I have resealed both Shark Fin & rear high mount light. Several videos on this on YouTube.
I have had both failures and leaks on my 2016. When the sharkfin leak happened, the dealer replaced the antenna under warranty and pretty sure it was a new design that was supposed to prevent this from happening again. You might want to check and see if the 2014 also had an updated design.
