I have a chance to buy a very clean 2007 cheap. The owner said he had his mechanic swap out the high mileage 6.0 with a low mileage 6.0. He says it starts and runs fine and then just randomly dies. It immediately starts back up and goes for a few days before doing it again. The truck is two states away so I wanted to get some opinions from this forum first. He did send me video of it starting and running.
He took it to a different mechanic that told him it could be the ECM. If it is an ECM issue and I can’t get the VIN from the donor vehicle should I just run the other direction? Thanks in advance!
Unlikely that it's a PCM problem. Sounds more like a bad crank sensor to me but that is just a guess. Bad crank sensors do that exact same thing.
And the VIN means absolutely nothing here, the VIN doesn't change how the vehicle runs. If the engines are the same engines in this swap, the computer would run it no problem.
Thanks, I had read that on other threads with similar issues. Also read it’s kind of a PITA to do. So, if that were the issue, would you hesitate driving it 5 hours to get it home? I know the preferred method is to trailer it, just don’t have the equipment.
It's a really simple repair in all honesty, 2 bolts to drop the starter out of the way and it's right there.
I'd probably still drive it.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
