I have a 2006 Yukon XL 2500 with the 6.0L, 4L80E transmission, and NV246 transfer case. It has the 4 buttons for 4wd (Auto, 2wd, 4H and 4L). I tested it with all four wheels off the ground and it appears to shift into each position, but the front drive shaft does not spin in any mode. If I put it in Auto it flashes "Service 4wd" and sets a C0374 code, and it won't shift out of Auto until I cycle the key. With the key on but engine not running I can hear the front axle actuator and the encoder motor operating. On a gravel road it shifts in and out of low range, but doesn't seem to get any power from the front drivetrain. The front actual actuator seems to be working.
From what I've read, it sounds like it is likely a failed clutch pack or chain, but before I drop the T-case I'm wondering if this can be caused by a faulty encoder motor? Is it possible that the encoder would have enough movement/power to shift it between the positions, but not actually engage the clutch pack?
Update: I pulled the drain plug and only got maybe an ounce or two of fluid and there are small chunks of something in it that I'm guessing are clutch packs. I found what appears to be a pinhole leak in the case from the pump ears. I'm guessing this means the clutches are probably toast. Obviously it will need a new case-back, but is it worth filling it back up with Auto Trak II fluid to see if it works, or am I just looking at needing a rebuild?
Edited by Steve N.
Adding an update
    • I really wanted to go to the Fox 2.5's But they were like ~$1,500 vs ~$425 for the Bilsteins. And my research on FOX shocks was that they do not have a great reputation for longevity. I am sure they the FOX's are fantastic, but I know from experience the Bilsteins are rock solid for at least 150k miles.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
