2 hours ago, richard wysong said:
look in the archives, it has been discussed many times
I have BUT they have been from a very long time ago so no one responds!!! Thank you though
Check the 1500 threads, think the interior on both models are pretty much identical.
i want to get ride of my jumper seat with locking underseat storage for a center console? i have not actually taken it out yet but it does look like it’s separate.
Edited by Gregory Krisa
