After 3+ months of waiting, my truck finally arrived. It’s a ‘25 LT. I received the replacement grill parts I ordered (chrome inserts for the otherwise black slats in the grill). After tons of internet searching I figured out how to remove the grill and replace them.
i know the majority move away from chrome, but I’m still a fan in the right amounts, especially the grill.
It’s only been 400 km, but I do like the truck. I upgraded from a 2013 LT.
Over the past week, I’ve installed a tonneau cover, running boards, screen protectors and gave it a full exterior detail (decontamination, clad bar, polish, and ceramic coat). Last thing was the grill.
here are a few pics and one of my old truck (also an LT dressed up like an LTZ).
Welcome to the forum. Beautiful truck!
