For sale set of Recovery Hooks from Chevy 1500 ZR2. Switched at dealer before bought the truck so brand new. Black on hooks in pic is grease.
$60 shipped.
Edited by wurgs
SOLD.
Thanks Phil!
Edited by wurgs
  • wurgs changed the title to Sold
  • txab locked this topic
This topic is now closed to further replies.
