Last Thursday I took my truck to the local dealer for a diagnostic (a flat $200) because it won't go into 4WD.  I told them the behaviors I observed:
  • The transfer case was shifting because I could engage 4LO and feel the torque
  • I couldn't tell if the front axle was engaging
  • The codes I had pulled pointed to the front axle not engaging
They told me it'd take 24-48 hours to diagnose and I was irritated because no one mentioned that and I needed my truck back by Tuesday (tomorrow as I write this).  He said he'd try.  On Thursday afternoon, he called and said they took it on a test drive and "found" some info and they wanted to pass along an update.  He then basically told me the things I told them and said they'd have to put it on a lift to go any further.  He'd try to get me on one first thing in the morning (Friday) and call me.
After radio silence all day, I called them at 4:45p on Friday not expecting much and they said they were just about to put it on a lift and would call me back.  He called me about 5:15 to say that they think the front actuator is faulty and needs to be replaced.  He couldn't tell me any more until they got more time on the lift on Saturday.
After yet another day of no communication, I called about an hour before closing and he said the actuator was failed and they want to replace it.  They couldn't tell me how much or how long until the parts department opened on Monday.  He'd get that set up and call me first thing Monday.
Monday, I get a call at about 1:30p to tell me "We think the actuator has failed.  We should replace that and see if that fixes it.  If not, we'll have to pull the differential and tear it apart."  The actuator was in Charlotte and since I missed his first call, they couldn't get it until Weds.  That would bring the bill to $755.  I was pissed....   They've had the truck for days and they still can't tell me anything more concrete than I told them when I dropped it off (It's probably the actuator).  I asked if they did any diagnostic tests to confirm the actuator was the fault and he said there weren't any notes to that effect.  Nothing to say they if they verified the power and ground to the actuator... Nothing to say they verified the signal is sent to the actuator correctly...  Nothing to indicate if they bothered to check if it was even plugged in.
So, to make sure I wasn't crazy I asked if he was suggesting I throw $800 of parts and labor at it and hope that fixes it and if not then I can spend another 3k to have them tear into the diff and he said "Yeah".  I asked exactly what was the point of the diagnosis because this wasn't acceptable.  I'm paying them for a diagnosis, not a second-opinion of the hunch I gave them 4 days ago.  I could have thrown parts at it with the information I had --and almost did.  I expected more professional work from the "The people that know my chevy the best" than this and they need to figure out if the $800 actuator is going to fix it or not.
He said that he'd talk to the tech and get back with me.  That was 2:30 and it's now after 6, so I assume I'll have to chase him down tomorrow.
My questions are...
  • Am I being unreasonable?
  • Is this what I should have expected?
Should just pick it up? They'll probably be happy never to see me again, but I hate to leave it like that.  I wasn't trying to burn a bridge...  Just to get an actual answer to, "What's actually broken?"
Edited by papageoff
  • papageoff changed the title to Am I the jerk here? (Dealer Service Issues) ...(^Probably^)...
18 hours ago, asilverblazer said:
I think if you PAY for a diagnosis, you should get a diagnosis.
Not pay for a diagnosis AND part changing/guessing.
Exactly.  Thanks for the reassurance.
On 5/20/2025 at 3:14 PM, papageoff said:
In other news, they never called today.  I've left 2 messages.
Update?
My questions are...
I don't think you're being unreasonable for 2 reasons:
1. Their communication is not great. You've had to chase them down after they missed the deadline they set for themselves. Nothing drives me more nuts. I totally understand shops getting frustrated with customers who call frequently demanding updates so I try to be patient. But if you tell me you'll call around a certain time and I have to track you down later that's when I'm not happy. Just be upfront with me if you're swamped and give me a more realistic timeline. Or call when you say you will and let me know you haven't been able to get to it yet. I can live with that because you're at least communicating.
2. Guessing it's a part and replacing it to see if that's the problem is not a diagnosis. They didn't test the actuator and that's absolutely part of the diagnosis process. Now it's a different story if they tested the actuator and found it to be faulty, got approval from you to replace it, then noticed something else with the differential when they test drove it after replacing it. Then it becomes, "we replaced the bad actuator and now think there's another issue. we need to get into your diff to find out more...".
I'd stay away from that dealership. Sadly I've lived in 7 states across the country and have only had good luck with 2 dealerships. Hopefully you can find a decent one near you or a competent independent shop. I'm fortunate the best dealership I've worked with is where I live now. They don't throw parts at stuff and pray it solves it...and they communicate well.
Edited by midwestdenaliguy
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
