Bought a 2025 GMC Sierra 3500 4x4 Denali to tow behind our motorhome. Was assured is was not a problem and even was showed protocol in owners manual.  Went with the Demco Air Force one braking system since MH I designed to supply air to tow vehicle thus avoiding any electrical connections.  Went with Etrailer plug and play wiring harness that connects into the tail lights.  Also went with the Etrailer system that charged the batteries as well. When I go through the protocol of getting ready to tow and the electrical connections is made I have all the lights in the rear of the truck.  The issue is when you put the truck in park the steering wheel locks up, obviously you cannot tow like this.  What I did next is disconnect the charging line to the battery, this makes the towed vehicle protocol go perfect and I can tow the vehicle.  The problem now is I have no lights on the rear of the vehicle. I think the problem is the module in the LED taillights, that need a signal rather then a 12 volt source. All the plug and play wiring from Etrailer have diodes in them. I have been getting nothing but the run around from the GMC dealer. Have called GMC help line and relayed exactly as above but not even a response.  Ran into another person towing a 2500 and had the same problem, and the same response from GMC.  He ended up putting magnetic lights on which look absolutely terrible.  Any suggestions out there.  As far as I am concerned I have a $90,000 vehicle which does not conform to federal standards.  Is that a reasonable assumption
Nothing I say is really going to help you feel any better here, but GM, as far as I'm concerned, is DEAD.
Based on past experience turning wrenches professionally for 14 years, owning a GM product for 16 painful years, and reading story, after story, after ENDLESS story of problems, I'd seriously recommend dumping that vehicle for ANYTHING else. Preferably something built when manufacturers still SORT OF gave a crap about their customers - at least something built before the 2007 model year. Your wallet and your sanity will thank me later.
And if that truck has the 6.2, you had better check up on that engine recall before the thing blows up on your next trip.
Edited by Jsdirt
Sounds like the stuff from E-trailer doesnt integrate with the truck. Not sure how that is GM's fault. The fact that it doesnt integrate with the upfitter items you tried to add isnt an indication IMHO of it not meeting any standards. The new trucks are very sophisticated electronically and ant changes to them can have far reaching implications. I would research as much as possible on RV forums for others with similar issues and see if they had solutions. It very possible that you will need to use additional lights other than the OEM ones on the truck. There are few, if any dealer level people that have the training and talent to troubleshoot issues like this. GM has little to no tolerance for people modifying the vehicles other than qualified upfitting companies. Just because a dealer made a claim that something would work for a particular purpose does not mean it actually will. Dealers are notorious for wild claims.
NOTHING should be this frigging complicated in making an attempt to do what it was designed to do, especially on a $90,000 truck.
What the hell good is a truck if you can't even tow with it because the G / D electronics won't let you? RIDICULOUS!
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,696 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
