Got a new truck today
Torque Junkie
We traded in the '96 V6 truck (aka the gutless wonder) for a '98 Dodge 3/4 Ton 4x4, 5.9L Magnum V8, Auto, towing package, 33" tires. We got it for right at book at $12k. It's got 104k miles tho, but it runs as smooth as silk.
looks fun, I'm thinking you'll have some off roading pics soon?
looks to be very stright and clean too :(
check this out, they are priced pretty good, and are genuine leather:
http://www.wheelskins.com/
unfortunately, they don't make anything to cover up that ram emblem :)
Hope you own a gas station... :thumbs:
:( Between the Dodge, my gas-guzzling '79 and my Z28, there's 24 cylinders and a LOT of gas consumption, so that is truly funny :dupe:
My wife's always wanted a Dodge, and I'd have preferred another GM (as they're more powerful and still use less gas) but I decided to have the wife happy ... if you know what I mean :)
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
