GM-TC Welcomes PCMFORLESS.COM
Zane
All of us here at GM-Trucks.com would like to welcome PCMFORLESS.COM as a new supporting vendor here at GM-Trucks.com!!
Bryan will be your contact, with the username PCMFORLESS :)
Check Them Out! :(
Thank you very much guys. It is an honor to sponsor a quality board like the GM-Trucks.com forum.
In celebration of this I would like to offer a discount of 10% on any PCM reprogramming where a customer sends in their PCM to be programmed for the month of March as opposed to an exchange PCM order. We currently already are offering our exchange PCM programming on sale at $250 including shipping plus the $125 core charge.
We hope to run more promotions in the near future, including our heads and cam package from our partners at JD's High Performance as soon as the results are in from my heads and cam project that almost finished. We also hope to bring you a less expensive alternative to the flex a lite fan package that will use LS1 fans and actually be controlled by the PCM instead of a sensor pushed into your radiator.
Thanks,
Bryan
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
