Buying a 2018 Escalade with 10L80 and 74k tomorrow. Maintenance history suspected to be good based on profile of PO and condition of vehicle but unknown. I'm planning to replace all fluids right off the bat so I'm working with a clean baseline. I'd like to own the vehicle for a while.
So in regards to the transmission, question is would it be better to have a full flush done or do a drain/refill + filter? Or should I shell out the money for a flush + filter?
TIA
TIA
On my GM I bought an extractor and pulled out through the dipstick. I measured out and put the same amount in. I did it twice one week apart. I wouldn’t flush any transmission. All my vehicles are on a 30K drain and fill. With the transmission if the fluid is bad you can smell it.
Drain, filter and refill. Then regular services afterwards, 25K, 30K etc., your choice.
I just looked it up and it appears there’s no dipstick. You have to go under, yikes.
It’s really frustrating not having a dipstick. What the hell was GM thinking!?  I have the 8L90 which also doesn't have a dipstick, so draining and filling the transmission is quite a hassle. I bought the pump shown below from Amazon, and it made the process of draining and refilling the transmission much easier and far less messy.
https://www.amazon.com/dp/B07N7YV5GN?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3&th=1
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,156 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
