I have a 06 GMC 2500HD, I hit the panel that is just below the bumper and did a job on it. Who makes good panels, Thanks
Steve
On 8/8/2025 at 7:30 PM, CamGTP said:
Have a picture of what exactly you are talking about?
Its  the panel directly below front bumper .
I'm going to assume you are asking about the black plastic Air Dam bolted to the bottom of the bumper?  You should be able to buy a replacement on-line.  On my 2012 GMC it was a two-piece air dam with one stacked below the other, I damaged the lower one the first week I owned the truck and just removed it and never looked back.
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
