Anyone heard of?
It's available in 1500 Series as in 1500 HD,Sierra C3/Denali,and Silverado SS only.
You also get it in the Escalade and Escalade EXT.
Frank is dead on,
It shows it as a 1/2 ton option only because it is available as a part of some 1/2ton packages.
Here you go. The truck has the B4V package on it. This will be exclusive to GMC and only available in TX, OK, and LA.
GMC • 2004 Sierra 1500 Extended Cab
SIERRA 1500 SLE EXTENDED CAB INVOICE RETAIL NEW CAR
BLUE BOOK
TC15753 2WD Pickup 4D 6 1/2 ft. 25,843.90 29,422.00 27,136.00
PRICING BREAKDOWN
Base Pricing 24,615.50 28,132.00
Destination Charge 850.00 850.00
Total Required and Optional Equipment 378.40 440.00
25,843.90 29,422.00
OPTIONAL EQUIPMENT
EMISSION EQUIPMENT
(All Orders Must Code an Emission Equipment)
FE9 Emission Equipment, Federal N/C N/C
VCL Emission Equipment Certification, Clean Fuel/LEV • SLE & SLT Ex. Fleet N/C N/C
ENGINES
(All Orders Must Code an Engine)
LQ9 V8, 364", HO, SFI (6.0 Liter)
(N/A Work Truck, Base, SLE & SLT 2WD w/8' Bed or SLE & SLT 4WD) (Req's Auto Trans.-M32) (Available & Included Only w/Performance Pkg.-B4V) N/C N/C
TRANSMISSIONS
(All Orders Must Code a Transmission)
M32 Automatic, H.D. 4-Speed w/Overdrive
(N/A Work Truck, Base, SLE & SLT 2WD w/8' Bed or SLE & SLT 4WD) (Available & Included Only w/Performance Pkg.-B4V on SLE & SLT 2WD w/6 1/4' Bed) N/C N/C
MARKETING OPTION PACKAGES
(All Orders Must Code a Marketing Option Pkg.)
1SC Marketing Option Pkg. • SLE
(N/A Work Truck, Base, SLT or Denali) (See Std. Equipment Listing) N/C N/C
ACCESSORY PACKAGES
B4V Performance Pkg. • SLE & SLT 2WD w/6 1/2' Bed
(N/A Work Truck, Base, SLE & SLT 2WD w/8' Bed, SLE & SLT 4WD or Denali) (N/A w/Mirrors-DPF, Battery-TP2, Steering Pkg.-NYS, Appearance Pkg.-B2E or Traction Control-NW7) (Available Only in Louisiana, Oklahoma & Texas -- Check Residency Requirements for Availability) (Req's Axle Ratio-GT4, Axle-G80, Cooling-KNP, Cooler-KC4, Body-E63, Paint-ZY1 & Emission Equipment Ceritification-VCL) Includes LQ9 6.0L HO Engine, Auto Trans.-M32, High Performance Suspension Pkg., Chrome Cast Aluminum Wheels & (4) P275/55R20 Touring BSW w/(1) P265/75R16BSW Spare Tire. N/A N/A
Z60 Suspension Pkg., High Performance • SLE & SLT 2WD w/6 1/2' Bed
(N/A Work Truck, Base, SLE & SLT 2WD w/8' Bed or SLE & SLT 4WD) (Available & Included Only w/Appearance Pkg.-B2E & Performance Pkg.-B4V) N/C N/C
GVWR PACKAGES
(All Orders Must Code a GVWR Pkg.)
Q4B 6200-lb. GVWR • 2WD Models w/6 1/2' Bed
(1637-lb. Payload) (N/A 2WD Models w/8' Bed, 4WD Models or Denali) (N/A w/Steering Pkg.-NYS) (See Std. Equipment Listing) N/C N/C
POWER ACCESSORIES
AU3 Door Locks, Power
(N/A Work Truck) (Std. SLE, SLT & Denali) Std. Std.
OTHER OPTIONS
K47 Air Cleaner, High Capacity • Work Truck, Base, SLE & SLT
(Std. Denali) (Std. w/Trailering Equipment-Z82, Suspension Pkg.-Z71 & TX/OK/LA/CA/FL/NM Pkg.-PDJ) Incl. Incl.
G80 Axle, H.D. Locking • Work Truck, Base, SLE & SLT 2WD
(N/A w/Steering Pkg.-NYS) (Std. SLT 4WD) (Std. w/Off-Road Pkg.-PDL & Power Pkg.-PDU) 253.70 295.00
GT4 Axle Ratio, 3.73 • 2WD Models
(N/A Denali) 43.00 50.00
E63 Body, Wideside N/C N/C
VB3 Bumper, Chrome Rear Step
(N/A Denali) (Std. Base, SLE & SLT) (Req's Body-E63) Std. Std.
KC4 Cooler, Engine Oil • SLE & SLT 2WD w/6 1/2' Bed
(N/A Work Truck, Base, SLE & SLT 2WD w/8' Bed, SLE & SLT 4WD or Denali) (Req's Performance Pkg.-B4V) N/A N/A
KNP Cooling, H.D. Auxiliary Transmission Oil • Work Truck, Base, SLE & SLT
(Std. Denali) (Std. w/Trailering Equipment Pkg.-Z82) (Req's Auto Trans.-M32 When in Combo w/Performance Pkg.-B4V) 81.70 95.00
C49 Defroster, Rear Window
(N/A w/Window-A28) (Std. SLE, SLT & Denali) (Available to Fleet & Government Orders Only on Work Truck) Std. Std.
AJ1 Glass, Deep Tinted Rear
(Std. SLE, SLT & Denali) (Rear Window is Light Tinted When in Combo w/Defroster-C49) Std. Std.
ZY1 Paint, Solid N/C N/C
UB0 Radio, AM/FM Stereo w/CD
(N/A SLT or Denali) (Std. Base & SLE) Std. Std.
AE7 Seat, Split Bench • Base & SLE w/Seat Trim-D N/C N/C
**D Seat Trim, Custom Cloth • Base, SLE
(N/A SLT or Denali) (First Two Characters Refer to Interior Color) N/C N/C
K34 Speed Control
(Std. Base, SLE, SLT & Denali) Std. Std.
TIRES--2WD MODELS
(All Orders Must Code a Tire)
QNL (5) P245/75R16 OWL • SLE & SLT After 2-23-04
(N/A Work Truck or Base) Std. Std.
STANDARD EQUIPMENT
Air Conditioning, Dual-Zone Manual
Alarm System
Alternator, 105-Amp.
Armrest, Front w/Storage
Axle Ratio, 3.42 (Must Code)
Axle, Front: 3600-lb. Cap.
Axle, Rear: 3750-lb. Cap.
Battery, H.D. 600-cca
Body, Wideside (Must Code)
Brakes, Power F&R Disc
Braking System, F&R Anti-Lock
Bumpers, Chrome F&R w/Rear Step
Carpeting
Clock, Digital (w/Radio)
Console, Mini Overhead
Cup Holders, F&R
Door Locks, Power
Driver's Information Center
Drivetrain, RWD
Emission Equipment, Federal (Must Code)
Engine: V8, SFI, 4.8 Liter (Must Code)
Entry System, Illuminated
Entry System, Keyless Remote Control
Floor Mats, F&R
Fog Lights, Front
Fuel Tank, 26.0 Gal. Cap.
GVWR, 6200-lb. (Must Code)
Gauges, Oil Pressure & Voltmeter
Grille Surround, Chrome
Headlamp Control, Auto
Lights: Daytime Running, Exterior Cargo & Reading
Marketing Option Pkg.-1SC (Must Code)
Mirror, RH Visor Vanity
Mirrors, Dual Heated Power w/Manual Fold & Inside Automatic Day/Night
Moldings, Body Side
Paint, Solid (Must Code)
Payload, 1637-lb.
Power Outlets, (2)
Restraint System, Dual Front Air Bag
Seats, Custom Cloth Split Bench (Must Code) w/Folding Rear
Speed Control
Springs, Front: 3739-lb. Cap.
Springs, Rear: 3686-lb. Cap.
Stabilizer Bar, F&R
Steering Wheel, Leather-Wrapped
Steering Wheel, Tilt
Steering, Power
Suspension Pkg., H.D. Handling/Trailering (Must Code)
Tachometer
Tire, Conventional Spare
Tires, (4) P255/70R16 BSW (Before 2-23-04) or (4) P245/75R16 OWL (Must Code) (After 2-23-04)
Tow Hooks, Front
Towing Cap., 8700-lb. Max. (When Properly Equipped)
Trailer Connector, 6-Wire
Trans., 4-Spd. Automatic w/Overdrive (Must Code)
W/S Wipers, Intermittent
Wheels, Chrome Styled Steel
Windows, Power
General Specifications:
2WD Models w/6 1/2' Bed: W.B. 143.5"; O.L. 227.7" (w/o Rear Bumper); Width 78.5"; Height 71.2"; Curb Weight 4563-lbs.
Warranty:
3-yr/36,000-mi Limited Bumper-to-Bumper; 3-yr/36,000-mi 24-hr Roadside Assistance; 6-yr/100,000-mi Sheet Metal Rust-Thru.
Engine Specifications:
Code LR4; VIN V; Cylinders V8; Liters 4.8; Fuel Induction SFI; HP 285; Torque 295
Code LQ9; Cylinders V8; Liters 6.0; Fuel Induction HO SFI; HP 345; Torque 380
EPA Estimated Miles Per Gallon:
2WD w/LR4 4.8L Engine: City 15; Hwy 20
2WD w/LQ9 6.0L Engine: City --; Hwy --
Thanks for the info, guess if I want that I'll have to buy property in LA:} Why is it that its limited to those states? Wish it was avalible in the Chevy 1500 other than a SS. I'd like the 6 liter in the new crew cab.
Yup yup, I just got off the phone with my local GMC dealer. This is TRUE. You CAN order a SCRB (GMC only) with the Denali 6.0L :cheers: But they must be ordered. Dealers will not carry these on the lot. The gentleman on the phone told me these trucks were actually 365 hp (anyone?), and are extremely quick...maybe not SRT-10 or Lightning, but definatly a sleeper.
That is probably a 1500 HD as stated earlier
The 1500HD only comes in crew cab and has
a GVW of 8600 #. This couldn't be the HD.
Yup yup, I just got off the phone with my local GMC dealer. This is TRUE. You CAN order a SCRB (GMC only) with the Denali 6.0L :cool: But they must be ordered. Dealers will not carry these on the lot. The gentleman on the phone told me these trucks were actually 365 hp (anyone?), and are extremely quick...maybe not SRT-10 or Lightning, but definatly a sleeper.
And I thought I has the smallest congfiguration with the largest motor :cheers:
The 1500HD gets a MT1 Transmission AKA 4L80E. This truck will have the M32 AKA 4L65E. The Denali currently gets the LQ4 6.0L. This truck will have the LQ9 6.0L which is the HO version of the 6.0L that is currently offered in the Escalades and Silverado SS. The Denali will not get the LQ9 6.0L until 2005.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
