I have a 2019 Sierra AT4 with a 5.3 engine. After experiencing a ground failure and replacing that along with a new battery, I found that I was left without 4WD. I scanned the system, but it didn’t show a TCCM (Transfer Case Control Module), so I thought it might be due to my cheap scanner. I upgraded to a new scanner, but it still didn't show the TCCM. However, when I unplugged the fuse for the TCCM and reinstalled it, I scanned again, and now it shows the TCCM with the code P062F-00.
My question is: Is there something I can try to get the 4WD working again, or am I looking at needing a new TCCM or addressing something else entirely? I tried clearing the code, but it keeps coming back. All the other codes cleared except for one related to the battery for the key fob, which persists after I installed new batteries. Additionally, the left-side camera has failed, but getting the 4WD back up and running is my main priority.
2019_GMC_Sierra_1GTP9EED0KZ160844_Report_2025-08-27 0452.pdf
Well, you might go through the diagnostic procedure for that code, to find what is causing it.  The TCCM might need to be replaced, but it might just have a bad power or ground connection, or something else causing it.
alldata.com will have a vehicle-specific diagnostic procedure you can work through, to find the cause, to then fix it.
Here is some general info found online. May be somewhat helpful.
_____________________________
What Does the P062F Code Mean?
The P062F code specifically refers to a failure within the PCM’s internal EEPROM (Electrically Erasable Programmable Read-Only Memory). This memory is crucial for storing data and configurations that allow the PCM to manage the engine and other components effectively.
What Causes the P062F Code?
Several factors can trigger the P062F code, including:
  • Control module failure
  • Powertrain Control Module (PCM) failure
  • Wiring issues that affect communication to and from the PCM
What Are the Symptoms of the P062F Code?
When the P062F code is present, you may notice the following symptoms:
  • Illumination of additional warning lights on the instrument cluster
  • Potential performance issues related to engine management
  • Unresponsive vehicle systems controlled by the PCM
How Serious Is the P062F Code?
The P062F code is classified as urgent, indicating that immediate attention is necessary. Ignoring this code can lead to significant damage to the vehicle’s systems and may pose safety risks to the driver and passengers.
How to Diagnose the P062F Code
To accurately diagnose the P062F code, follow these steps:
  1. Use an OBD-II scanner to confirm the presence of the P062F code and check for any accompanying codes.
  2. Inspect the wiring and connectors related to the PCM for any signs of damage or corrosion.
  3. Perform a visual inspection of the PCM itself for any physical damage.
  4. Check the vehicle’s battery and charging system, as electrical issues can affect the PCM’s performance.
  5. Consider running a PCM self-diagnosis test if available.
Common Repairs for the P062F Code
Repairing the P062F code may involve:
  • Replacing the faulty PCM
  • Repairing or replacing damaged wiring and connectors
  • Resetting the PCM and reprogramming if necessary
How Much Does It Cost to Fix the P062F Code?
The cost to fix the P062F code can vary widely depending on the specific issue and whether you need to replace the PCM. On average, you can expect to pay:
  • PCM replacement: $800 – $2,500
  • Wiring repairs: $100 – $500
Can I Fix the P062F Code Myself?
While some aspects of diagnosing and repairing the P062F code can be tackled by experienced DIYers, such as inspecting wiring and connectors, replacing the PCM typically requires specialized knowledge and tools. For most vehicle owners, it is advisable to consult with a professional mechanic to ensure proper diagnosis and repair.
I was reading about this on Google the other day, and my situation is that there is no engine light on and I have no issues other than the fact that my four-wheel drive (4WD) isn't working. Everything else is functioning perfectly.
This problem started after I had a bad ground issue, which led to a no-start condition. I found and replaced the faulty ground, but now I can't engage the 4WD. Initially, the Transmission Control Module (TCCM) wasn't showing up until I pulled out the fuse and reinstalled it. Now, I have a long-term memory issue, and the code is showing up under my TCCM module. I'm not sure if the problem might be related to the Transmission Control Module (TCM).
i was talking with a guy to day he said that the transfer case motor is a big problem with them so gonna throw a rock in the dark and hope it works
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,867 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
